Working on an Engine Simulator
Old Apr 25, 2026 | 05:04 AM
forcd ind's Avatar
Pretty cool, but I can see I would never be able to figure it out, lol.
Old Apr 27, 2026 | 02:42 PM
pblawler's Avatar
Originally Posted by FSAE_Junkie
I'll admit, when i first saw this, i thought it was going to be a low effort, simple empirical model, but it appears to be more than that.
It looks like when solving for VE you are using some empirical equations with a helmholz equation. Im not sure what your background is, but have you considered trying to actually solve the 1D wave equation in the intake runner to get a true 1st principles physics prediction of VE? I feel this is what separates the Desktop Dyno softwares of the world from real, full physics based engineering tools like GT-Power. No doubt this would slow the simulation down, and is not trivial to implement, but I'm curious what your end goal is.
I just pushed an update. I updated the VE calculations, the current model uses a flow model based on cam/head flow/piston speed, intake runner length (flow harmonics), etc... I'll continue to improve on it, the current model is pretty good. I will be loading more options to the parts libraries soon also (243, 317 heads, Holley Hi Ram, etc...). Send requests for additional heads, cams, and intakes.
Old Apr 28, 2026 | 11:03 AM
pblawler's Avatar
I updated the exhaust sim which affects quite a bit of other calculations and now the numbers are looking pretty good. I added several head and cam options to the library also. I added an injector vs pressure rating calculator, an injector sizing calculator and an power/ET/Weight calculator.
Old Apr 30, 2026 | 02:56 PM
pblawler's Avatar
I made several calculation improvements as well as interface updates. It's now possible to copy values from a spreadsheet (like Excel) and paste them into IAT, VE, AFR, and Timing Table (albeit the grid sizes need to match).
Old May 13, 2026 | 06:14 PM
pblawler's Avatar
I have posted a several updates and the calculations are looking good. I will post the desktop app in the Microsoft store soon.
