FMIC install started....pics in here...
Old Jul 30, 2004 | 09:07 AM
Tiago's Avatar
Originally Posted by 5-liter-eater
Stupid firebirds !!! Anyone attempt this on a camaro, doesnt look like it would fit as well.
here is one camaro I did:
http://www.forcefedfab.com/images/PICS/korben/47.html
I will be doing a 98 + car soon as well.
Old Jul 30, 2004 | 09:28 AM
PurEvl's Avatar
oh sweet....thanks alot. IS there a part number and place to get that?
Old Jul 30, 2004 | 10:04 AM
Tiago's Avatar
nah its all custom stuff...
Old Jul 30, 2004 | 10:05 AM
buschman's Avatar
Looks very well done Jeremy. I can forsee my next mod now. Can you PM me the details of your install as well? How much surface area is blocked by the bumper? Did you have to remove the bumper support?
Mike
Old Jul 30, 2004 | 10:49 AM
granitemonkey's Avatar
Great Pics J Looks very clean and professional like
frcefed98's Avatar
Thanks all
Blackbird, I'll PM you with all the info
Smokinhawk, I'll have those pics up today. We were test fitting the nose in the above pic to make sure it went on. stay tuned...
Rice Etr, yep all the work is done here in the driveway The motto is "if it isn't done on ramps, jackstands and a jack, it doesn't count.
5Litereater, bring me a camaro and I'll do one for you
Lookin good Tiago and thanks for the help
Buschman, a lot of the core is blocked by the small opening, but its now quite cavernous in there, so it should still get a lot of air. I'll pm you some things in a sec
J
Old Jul 30, 2004 | 10:51 AM
frcefed98's Avatar
Brandon, I just hope the rest turns out well, I still want to bring the IC up a lil higher, but that will all be worked out today and Thanks
Old Jul 30, 2004 | 10:55 AM
Blackbird's Avatar
you should have your airbrush guy do up the exposed part of the IC
Old Jul 30, 2004 | 11:23 AM
slow's Avatar
pm me about the bends please
looks great
Ryan
Old Jul 30, 2004 | 12:12 PM
NA$TY-TA's Avatar
Lookin good........... That is all... he he
More pics..... the first time i go out drinkin in months and you post up the good ****...... Mine should be to me next week.
Kyle
Old Jul 30, 2004 | 12:18 PM
taqwache's Avatar
Kyle
drinking. why no invite.
Old Jul 30, 2004 | 12:21 PM
  #32
NA$TY-TA's Avatar
Sorry Steve...... i went with a buddy of mine from Rockport. We used to be on the same boat togeather in Hawaii. Ill call ya next time we go out.... went to Stinger and lots of T&A..........
You going to the Valley tonight to run?? I am. Ill try not to break something.
Kyle
Old Jul 30, 2004 | 03:12 PM
  #33
buschman's Avatar
Kyle
Like fur shur... like like like i tooootally ran an 11 dude.... fur shur.
what......... EVER! oh.... my.... gawd!
Track times and Valley talk is fun.
Mike
Old Jul 30, 2004 | 03:55 PM
  #34
frcefed98's Avatar
Ok Ok Back on track fellas
You guys asked for more pics so here they are. It is now mounted completely in the car. All that is left is to cut the bends up, but that will have to wait till tomorrow. I have to watch the lil guy for now
I did this with an outlay $11.83 for supplies(4-8x1.25mm capscrews, lockwashers, washers and a 36inch 1/8in flat piece of steel stock all from homedepot racersupply). I wanted to retain the bumper support somehow and was able too. I am glad I did this cause it saved some money cause I used what I had. Great benefits are I can remove the FMIC anytime I want because it isn't permanetly attached to the car, and the FMIC is mounted SOLIDLY to the car, this thing doesn't budge I have good clearance about 1/2 inch between the back of the FMIC and the washer bottle stuff and great clearance on the sides and the bumper nose fits around the bottom nicely. I might cut the bottom of the nose cover a lil so it will fit tighter than it already does. If I do I will take pics of how it worked out. But it fits nicely and is removable and has lots of room to breathe. Thanks Merlin(frank) for lending a hand this morning(almost lost one to J's grinder of doooom )
So here goes the pics.
*pics removed* Webspace needed for another project.
I used the center brackets that were in the bumper support(cut them out) for the bottom support brackets for the FMIC and welded a length of 1/8 flat steel to them. I then cut two 8inch lengths of flat steel and welded them to the bottom of the bumper support brackets and then to the bottom FMIC brackets(former center bumper support brackets) at an angle. This worked out nicely. When drilling the bolt holes for the FMIC to bolt to, make them a lil big to make sure you can line up all the mounting tabs correctly. Nothing complicated or too hard and went up without a hitch
J
Old Jul 30, 2004 | 04:29 PM
  #35
-=Merlin=-'s Avatar
Anytime Jer!
What time are you going to start tommorow morning?
My water pump just arrived so I'll probably get that sucker bolted up this afternoon and finish up in the morning. Won't have it done by the time we go to the track
We need to plug up the open area around the end tanks somehow. To prevent the air from going around the IC.
Old Jul 30, 2004 | 04:54 PM
  #36
frcefed98's Avatar
I am going to start at 10am again. Cutting everything won't be too hard. Glad you got the WP, there is always next friday, we can take em both out
My brother pointed out a good thing too, since I have my fans mounted to the front of the radiator, they will be pulling air through the FMIC too, thus cooling it off faster, sounds like it might work. We can fab up a sheet metal "box" to go around the face of the FMIC to force it to go through, shouldn't be too hard
J
Old Jul 30, 2004 | 05:26 PM
  #37
maddboost's Avatar
I dont know about keeping that plate infront of the intercooler. Would like to see a comparison of your IATs with the cover off and on when you get the car running.
Old Jul 30, 2004 | 08:50 PM
  #38
BIGBOS's Avatar
I'm STILL waiting on GRIFFIN to get me my intercooler, its been well over a month now.....
Bastards...........
I e-mailed them, so we will see how long it takes them to reply *IF* they do.....
Jer, get that thing on the street so we can see what the good word is w/the boost levels
Old Jul 31, 2004 | 01:06 AM
  #39
frcefed98's Avatar
Maddboost, no comparision needed because IAT's are not a big factor if I'm putting around town. When I get into the boost it is only at the track or dyno the cover will be off, THE PLATE COVER IS ONLY FOR PROTECTION WHEN DRIVING THE CAR ON THE STREET and when on the street I never do anything besides cruise around, too old and have too much money invested to lose it street racing or doing anything WOT on city streets, the car is loud and cops are everywhere in ALB.
Bos, man that sucks to hear, hopefully it will show up soon. We will have some good info by friday of next week if not sooner. We will be doing the IC pipes in the morning.
J
Old Jul 31, 2004 | 03:13 AM
  #40
NA$TY-TA's Avatar
Mike
Wrong Valley...... were in TX Did ok..... picked up MPH, ran a tenth slower then my best, with a .2 tenth slower 60' with 5 psi less boost then before. Im happy. Time to get my FMIC on and ditch the stock drivetrain.
Jer, The pics said removed..... i want to see them since we have the same FMIC.... email them to me or PM them to me. Ill be gone the rest of the weekend......
Kyle
