Initial SDCE Tensioner Results
Old Aug 3, 2004 | 05:23 PM
BlwnTA's Avatar
7 Second Club
Default Initial SDCE Tensioner Results
After some brief street testing the SDCE set-up has held up well ( Scott and Wendy). Keep in mind the car has not been tuned properly yet, the last tune was put in about 20 miles before today so the PCM has not finished "learning" and most importantly my fuel set-up sucks .
12 PSI @ 6000 RPMS thru the ATI Twin IC's
The tensioner is sitting around 12-13 on the indicator so I need to tighten it up a bit to ensure no slippage but it didn't feel as if it was slipping during a quick run.
Here's the problems for me at least the fuel pressure went from 60PSI down to 35 PSI so it looks like that's the last hard run I make until I get my Racetronix P&P with a pump booster and FPR (which should be in a week or so )
Mark
Old Aug 3, 2004 | 05:54 PM
NA$TY-TA's Avatar
Mark,
What size blower pulley? 3.4" ????? 12 psi is awsome thru a built 408.
Kyle
Old Aug 3, 2004 | 06:44 PM
BIGBOS's Avatar
Yea, my tensioner is at 12-13, I'm running the 3.4" pulley and see a consistent 11psi with my 370 motor with a 214/218 cam.......I ordered a 3.2" I want more boost
Old Aug 3, 2004 | 08:59 PM
BlwnTA's Avatar
7 Second Club
Originally Posted by NA$TY-TA
Mark,
Kyle
Yep 3.4, It jumps to 10 psi at about 5000 rpms pretty quick then gradually climbs to 12. I may try a 3.2 down the road but I need to get other issues resolved (fuel) and a good tune before I tweak it....if I do at all .
Mark
Old Aug 3, 2004 | 09:17 PM
NA$TY-TA's Avatar
What injectors Mark??
Kyle
Old Aug 3, 2004 | 10:53 PM
buschman's Avatar
Congrats, glad to here the SDCE setup is working out for you. Let us know if the new racetronix pumps work out for you.
Mike
Old Aug 4, 2004 | 12:53 AM
BIGBOS's Avatar
Yea, I will see 12 on a GOOD night, hopefully with just the 3.2" it will bump me to at least 14psi, then when I put the FMIC on I hope to gain at least another 2psi and be able to bump up the timing to use this 100 octane gas I'm running at little better than I currently am.....
I also got to send my TQ converter back to get looked at, I think its got major slippage
Old Aug 4, 2004 | 12:55 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Slap a big cam in Bos it's time to make real power... then we can trailor you to GLD.
Old Aug 4, 2004 | 01:09 AM
1dirtyZ's Avatar
anyone been able to get a hold of sdce lately?
Old Aug 4, 2004 | 02:35 AM
nbm00ws6's Avatar
I talked to Wendy yesterday/Monday.
Tom
Old Aug 4, 2004 | 03:39 AM
1dirtyZ's Avatar
cool,
guess i'll try them again tommorow.
Old Aug 4, 2004 | 06:01 AM
BlwnTA's Avatar
7 Second Club
Kyle
Mototron 60's
Old Aug 4, 2004 | 06:02 AM
BlwnTA's Avatar
7 Second Club
What timing are you running now? I'm at 18 degrees with 100 Octane and no alky. Hope to get up around 20 with tuning and alky.
Mark
Old Aug 4, 2004 | 11:09 AM
NA$TY-TA's Avatar
Originally Posted by BlwnTA
Mototron 60's
Aftermarket fuel rails??? Stock feed and return?? dual intanks should work for you and that is all you should need if you have the other stuff done.
Kyle
