Fuel system help
Old Aug 10, 2004 | 08:44 PM
BOOSTAT4500's Avatar
Default Fuel system help
I have a 408 with a D-1SC. at about 6-7psi. Right now the only fuel system mods are a 255L in-line pump and 60lbs. injectors. Will this be enough for about 600rwhp? If not, what else do I need? What will be the limits of this system? Thanks.
Old Aug 10, 2004 | 09:28 PM
2FAST4U's Avatar
Injectors are fine but the pump isn't! There are many people like MightyMouse that use a dual intank pumps and a bigger feed line. I went overboard and went tank,weldon 2015,-10 lines,rails,pro regulator, step down pump box, ect... well I was told after a fellow drag racer saw it that my fuel system will support 1200hp! That is about twice the power I have! I call it room to grow!
Old Aug 10, 2004 | 09:46 PM
PurEvl's Avatar
fuel
Walbro 340l intank -single
-8 feed to Nasty fuel rail's
Aeromotive regulator set at 52 PSI -line off
-6 return
60lb Motrons
Handles my power easily, check sig
Old Aug 10, 2004 | 10:31 PM
Slowhawk's Avatar
LS1Tech Sponsor
You just need to add a return fuel line and some rails.The problem is the fuel feed line dries up under high load/HP.
Old Aug 11, 2004 | 02:43 PM
Would adding a KB boost-a-pump be enough for me for now, or will I still fall short? I know a couple of turbo 5.0 guys using these and having great results.
