turbo fuel system help
Old Aug 11, 2004 | 03:51 PM
ss01layinwheel's Avatar
Question turbo fuel system help
well i got some awsome feed back on what turb system to got with. now before i buy the kit i have to do the fuel system.
i was going to go with a walboro 255 lph intank pump, 50 or 60lbs injectors.
my question is do i need to get a regulator and run a return line or can i just use my hp tuners to mess with the pressure? and will this set up be sufficiant?
Old Aug 11, 2004 | 03:55 PM
Wildman's Avatar
Instead of the Walbro, you should consider the Racetronix PnP setup.
Old Aug 11, 2004 | 04:52 PM
MECHAM's Avatar
im pretty sure that racetronix uses a walbro pump. i have the racetronix setup and so far its only PNP for a 98 car. I seen a few threads about making them PNP for later years but dont know the result.
ss01layinwheel - before we can accurately answer your question. need to know
engine size
boost levels
if you are going stock motor with 5psi...i would suggest a single walbro and 60#injectors.
with a forged bottom end...i would suggest same injectors and dual intanks.
Old Aug 11, 2004 | 04:56 PM
stock internals for now, low boost on the street and as much as i can pack into that bitch at the track.
Old Aug 11, 2004 | 05:00 PM
MECHAM's Avatar
you should be fine with 60# injectors and single walbro GSS340M
Old Aug 11, 2004 | 07:46 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://www.racetronix.com/RX-F99-FPKG-2.html
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Aug 11, 2004 | 07:49 PM
Wildman's Avatar
Originally Posted by Racetronix
I tried to tell them.
I don't think you can beat this system at the price and the insurance it gives you. Just my opinion though.
Old Aug 12, 2004 | 12:11 PM
do i have to get the wiring harness with the racetronix pump? or can i just put it in place of my stock pump??
Old Aug 12, 2004 | 01:56 PM
Wildman's Avatar
As of right now, I do not believe you can purchase the pump seperate from the harness. But you can just buy a harness by itself, go figure.
Check out Thunder Racing, they should be shipping any day now.
The harness makes things a lot easier. Just unplug the stock wires, pull your stock pump, put your new pump in, plug in the new harness and voila!!!.
