MAF placement
Old Aug 12, 2004 | 04:09 AM
BlackNiteWS6's Avatar
Default MAF placement
I know this subject has been going back and forth many of times. But where is the better spot to place the MAF? Vortech uses a pull thru system. So do most of the turbo kits. I did some searching and noticed that Vortech people aren't seeing surging. Plus our MAF really wasn't designed to see hot pressurized air. Wouldn't the PCM get a more accurate reading if the MAF was on the blowers intake side? I think running a Pace descreened 85mm MAF after the filter on the intake side should work better. I had a Powerdyne on my '95 LT1 Z28 and it placed the MAF on the intake side and my car never surged at all. I seen that some people have their opinions about this, but i think if the Vortech kit and most others run a pull thru design it can't hurt. Plus the tuning and the use of a MAFT is possible and the MAF won't get maxed out i would think. Just my .02
Den
