How much boost on pump gas?
Old Aug 16, 2004 | 01:07 PM
Just Floor It's Avatar
Default How much boost on pump gas?
Just wondering if you are doing a 9.1:1 motor, how much boost can you get away with SAFELY on pump gas?
Thanks
Old Aug 16, 2004 | 01:11 PM
1point3liter's Avatar
I would think 12ish, but in reality it will depend on your tuning.
Old Aug 16, 2004 | 01:56 PM
MECHAM's Avatar
are you talking supercharged or turbo?
does it really matter?
and what is pump gas? 91 octane is pump gas here but I am ~6100-6700 ft
Old Aug 16, 2004 | 02:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
With alky?
I'd say with a FMIC and no alky, probably 650rwhp. I think 700rwhp might be a reach not sure.
Old Aug 16, 2004 | 02:51 PM
99Fbody99's Avatar
An even bigger question is Will it be intercooled?
Intercooled 9:1 and 94 octane fuel can pretty safely be run in the 13/14ish range.
Old Aug 16, 2004 | 06:51 PM
With Alky, and without alky...
Premium Gas(93)
Old Aug 16, 2004 | 07:33 PM
MIGHTYMOUSE's Avatar
instead of boost yea talk horsepower.. I did 635rw (346ci) on 92 octane.. i agree 650 could be had if you get special with the tune. that was roughly 12psi for me
i did 765rw on 93 and a single alky nozzle 635ml. that was peak 16.4psi
now i have the dual nozzle on the car and will be re dynoing again 19 psi pump/alky.
Old Aug 23, 2004 | 07:22 AM
chuntington101's Avatar
So you guys are saying you could run around 12psi on a bone stock motor and pump fuel, with an intercooler?
Excuse my ignorance but us brits don’t get big cc V8 like you guys do. That cool any way.
Thanks Chris.
Old Aug 23, 2004 | 07:55 AM
cablebandit's Avatar
12ish is on a 9:1 motor...not stock compression
Old Aug 23, 2004 | 09:57 AM
MYTURBOT/A's Avatar
Hmm? I was running 14psi every day on a 9.3:1 comp. motor in the FL heat with absolutly no problems and 16* timing @ tq peak. 20* @ hp peak. This was also on my TTi kit with outrageous back pressure and a inefficent intercooler.
Old Aug 23, 2004 | 10:40 AM
Again, pardon my ignorance, but what is the stock compression ratio of the LS1?
What would be the highest pressure on a bone stock engine with a cooler?
Thanks Chris.
Old Aug 23, 2004 | 10:57 AM
2FAST4U's Avatar
Mightymouse or PSJ !
Ok say 9.1:1, 348ci,Incon with Gen7! Only no NOS or alky! Oh and 55lb injectors and 93pump gas! Can I go 650hp-700hp.
I am thinking the injector is to small! The fuel line and pump will support 1200hp! I will change injectors if it matter! But not just for 50hp!
Thanks, William
Old Aug 23, 2004 | 11:07 AM
i dont think you should hope for more than 650.. that is at the tires..
myturbo, my guess is that you were making a lot of intake pressure sure, but it wasnt getting into the cyl. to make the hp we are talking about.
Old Aug 23, 2004 | 12:54 PM
WS-Sick's Avatar
When are you dynoing? I would love to see what you lay down and run after that.
Old Aug 23, 2004 | 01:09 PM
LS1Tech Co-Founder
I'm with MMouse, 650rwhp should be attainable but I think you need 60lb Motrons or maybe those RC Eng. 75's.
Old Aug 23, 2004 | 01:43 PM
i did saturday, car has had some ignition problems as of late, and only one clean pull on the dyno was made at 740something rwhp on a 96* day w/ pump gas
