Gears with turbos...
Old Aug 21, 2004 | 11:33 AM
BADSZ28's Avatar
Question Gears with turbos...
What rear gears are good for a turbo M6 car? I am conciderring going with the STS kit and recently picked up some 4.10s. Will I benifit from these gears with the STS or any turbo kit for that matter? Or is a lower number gear better for this. I already have 3.42s in the car. Any feedback is appreciated.
Thanks in advance.
Old Aug 21, 2004 | 11:47 AM
F8L Z71's Avatar
12 Second Truck Club
Personally I'd keep your stock gears.
Turbo's need load to really work well so most people stay with high gear ratios like 3:42s and below.
Besides, you'll have better gas milage and you wont take the risk of breaking a 4.10 which is not the strongest gear set and you don't risk the ugly whine that some get when you swap. Just my opinions *shrug*
Old Aug 21, 2004 | 01:05 PM
trtturbo's Avatar
I have 3:42's with my m6 sts car. When boost hits in first, it just spins. I too, would stick with the stock gears. Just my .02
Old Aug 21, 2004 | 04:10 PM
z98's Avatar
z98
When the throttle hits in first in a stock LS1, it spins...
Old Aug 21, 2004 | 05:21 PM
1QWIKZ's Avatar
stick with stock. turbos generate enough low-end to make up the lower(numerically) gear difference.
Old Aug 21, 2004 | 08:25 PM
cablebandit's Avatar
I took out my 3.42 and put in 3.23 gear with a 3900 lb car. I layed 30' of posi yesterday before I let off the gas........on the interstate at 60+ mph. You should leave the 3.42. The turbo will love him!!!! Mike laid down a 9.90 run with 3.50 gears
