Questions on Snow Methanol Inj. Kit
Old Aug 23, 2004 | 01:34 PM
Earl H's Avatar
Default Questions on Snow Methanol Inj. Kit
I’ve been looking at methanol injection kits (Snow, Alchycontrol and SMC). All seem to have their good points and bad points. Right now the Snow kit seems to come out on top, from the standpoint of price, ease of installation, kit components, etc. I like the progressive control, shurflo pump, etc. What I don’t like is the use of nylon (non-braided steel) lines. For you guys that are using the kit, is this an issue? How do you like your kit? Would you have gone with the other kits now that you’ve installed the Snow kit? How hard was the install? How long did it take?
Old Aug 23, 2004 | 01:40 PM
MIGHTYMOUSE's Avatar
took me an afternoon, though mine was a custom install and i do not run the controller.
give matt a call and ask him about the lines, i have had no problems with mine and are easy to custom fit with a razor blade to whatever length you want.
Old Aug 23, 2004 | 07:34 PM
Earl H's Avatar
Dave,
Is there an on/off adjustment on the unit?
Old Aug 23, 2004 | 08:37 PM
not without the controller there isn't.. however i provided my own through my boost controller.
Old Aug 24, 2004 | 07:25 AM
Rune's Avatar
Can i use my windshield washer tank ? with Methanol ? or a mix of methanol and water ?
And what kit should i go for if i can use my tank ?
( have 730rwhp right now , but want more :-)
TIA
Old Aug 24, 2004 | 10:58 AM
rune i put up a large post on my set up that quickly fell off the map.. i guess the interest is sporadic.. but you will find it in search or a couple pages back
i use my stock washer tank with straigh meth and used to use water mix
Old Aug 24, 2004 | 11:01 AM
mkoch1's Avatar
I just picked up an alky control progressive kit. Juilo (the owner) couldn't be more helpful on the phone. Customer service gets an A+. I recieved most of the kit already and it looks pretty good.
mark
Old Aug 24, 2004 | 11:22 AM
Earl H's Avatar
Just ordered the alchycontrol kit.
Old Aug 24, 2004 | 01:23 PM
Rune's Avatar
Thanks i found it, now i am in doubt :-) Snow kit or Alcy kit :-)
I also use E-boost, so maybe i can get away with a custom kit without controller and tank ? just high pressure pump, lines , nozzle, wiring etc
Old Aug 24, 2004 | 01:43 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I talked to Matt @ Snow the other day, very professional.
I'm making 740rwhp now, might make 800rwhy in the fall, he reccomended stage II with the controller.
Old Aug 24, 2004 | 03:56 PM
thats what i did, but i imagine either company can sell you in parts.
