? on Incon Fuel Pressure Regulator
Old Aug 25, 2004 | 08:08 PM
Mark C's Avatar
Default ? on Incon Fuel Pressure Regulator
Does anyone know if the fittings on the Incon regulator are removable? I've put a wrench on them and they don't look like they are coming out. If I knew they were screw in pipe threads, I don't care if I break the regulator getting them out.
I'm talking about those male GM fuel quick connect things.
I want to swap it out for a CAS regulator that I bought, and I can't find any commercial fittings for retail.
Hell, if I could buy two pieces of aluminium with those GM ends, I'll weld them to the fittings that came with the CAS part.
Thanks.
Old Aug 27, 2004 | 04:44 PM
DaveSchott's Avatar
I took mine apart, after installing a weldon, they are pressed in.
Old Aug 27, 2004 | 06:21 PM
red ws6 99's Avatar
Thanks.
Yep pressed in. You can get adapters from these guys:
www.performanceplumbing.com part number: 5800. Or you could cut the flare off of the aluminum tube and use a hardline to hose adapter, etc.
Either of guys have ls1-edit and a 99 car. My computer crashed and no more ls1-edit.
Gary
Old Aug 27, 2004 | 07:29 PM
Mark C's Avatar
Thanks, but the 5800 is the female part.
Basically, if I remove the Incon regulator, I have a plastic line with a female end in, and a plastic line with a female end out. I need to attach two male GM EFI fittings to the regulator.
I could use the 5800's in conjunction with two short pieces of hard line with male ends, which I know I can buy... but a single adapter would be cleaner.
Old Aug 27, 2004 | 08:54 PM
red ws6 99's Avatar
The male quick connect is just a flared piece of tube, a hydraulic shop might have the necessary tool. Or you could just buy a fuel filter cut the ends off and weld them to AN fitting.
Gary
Old Aug 28, 2004 | 08:26 PM
Mark C's Avatar
Gary
My thoughts exactly.
