Upgrade to Vortech T trim from S trim
Old Aug 31, 2004 | 12:54 PM
black01ws6's Avatar
Default Upgrade to Vortech T trim from S trim
I've searched the forums and still haven't quite found a complete answer for the problems that may arise with my setup. I've been running with a Vortech S trim kit on my 2001 WS-6 for a couple years now and I'm currently building a motor. Along with the motor I want to upgrade to the T trim blower. My main question is will the T trim fit my current S trim bracket as it is? If not can it be modified? If I need a completely new bracket where do I get it? Are there any other fitment issues I'm going run into?
Thanks for any input.
Old Aug 31, 2004 | 01:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You are running an S-Trim or the SQ G-Trim supercharger?
You would need different brackets. T-Trim is physically bigger than a S-Trim head unit.
RMCR sells brackets, but you might want to also ask tom@ls1speed.com if he makes some too.
Old Aug 31, 2004 | 01:34 PM
MelloYellow's Avatar
At least on the Corvette, the S-Trim and T-Trim use the same bracketry. The only difference is the size of the inlet hole. The inlet is .25" larger with the T-Trim.
But, for an F-Body you normally have a G-Trim unless you have a custom S-Trim bracket right now.
