Qmp kit overboosting?
Old Sep 3, 2004 | 08:36 AM
Tiago's Avatar
take a single vaccum source form the intake manifold and split it into two. One for the BOV and another for the WG (side port, leave teh bottom port open to the atmosphere). Plug the fitting on the turbo if you have one. See what that does.
Old Sep 3, 2004 | 10:05 AM
MIGHTYMOUSE's Avatar
putting it at the intake vs the turbo discharge will allow for even more boost if the w/g is wacked. the safest route would be straight off the turbo before the intercooler or throttlebody..doncha think?
Old Sep 3, 2004 | 10:09 AM
69firebird's Avatar
are you sure, ive been told by alot of people that you want a dedicated vacuum line from source to wastegate.
Old Sep 3, 2004 | 10:21 AM
Tiago's Avatar
if its wacked it wont make a difference, but a reading straight off the turbo will probably yield less booost in the case that it works. Ive done it both ways.
if you can dedicate the signal for the wastegate then it go ahead and do that, but Ive never had trouble sharing it either.
Old Sep 3, 2004 | 10:23 AM
69firebird's Avatar
ok im not doubting, ive just had alot of turbo guys locally say dont share the wastegate line, im going to have to since I have twin kit. bit I have a sheel metal intake, so I can almost have as many ports as I need just drill and tap, drill and tap lol
unusual any luck?/
Old Sep 3, 2004 | 11:13 AM
black98ws6ta's Avatar
Default ?
I'm confused, in your first post u said you hit the wg with a hammer and it then fliudly moved. Then after being asked if u called Qmp, u responded that they reccomended that u try to free the wg by hitting it with a hammer, then said that it didnt not work? Which one is it?
Old Sep 3, 2004 | 11:40 AM
MECHAM's Avatar
I believe what he is saying.
1st he notice the WG was stuck, hit it with a hammer. this didnt fix the problem.
2nd he called QMP for their expertise, they recommended hitting it with a hammer.
he already did that in step 1 and it didnt fix the problem.
Old Sep 3, 2004 | 11:50 AM
ooh i got a good one.. just for the heck of it is the wastegate mounted backward? I cant remember if the flanges are the same on either side or not.. i want to say no.
Old Sep 3, 2004 | 12:01 PM
MECHAM's Avatar
hey now!!! im the only one that can do that
Old Sep 3, 2004 | 12:19 PM
Unusual T/A's Avatar
is it fast?
At 4th gear with 1/2 throttle the car would break lose all over the road so I would say yes. I will keep you guys posted we're playing with a couple things now.
Its mounted the way it came with the kit.
Old Sep 3, 2004 | 12:25 PM
  #32
so the top port of the w/g is facing the ground, not the radiator correct?
Old Sep 3, 2004 | 12:51 PM
  #33
Yes the top IS facing the ground.
Old Sep 3, 2004 | 07:04 PM
  #34
Update: Changed up the wiring according to you guys. The car sees a flat 10lbs. So now I get to figure out how to wire up this silly HKS EVC5. Thanks for all the help guys.
Old Sep 3, 2004 | 10:43 PM
  #35
KHShapiro's Avatar
kwel it was an easy fix.
Old Sep 4, 2004 | 07:28 AM
  #36
SS00Blue's Avatar
Glad it's running right!
Old Sep 4, 2004 | 10:33 AM
  #37
I'm GLAD the wategate works!
Old Sep 4, 2004 | 04:43 PM
  #38
xssive's Avatar
Bad ***. Finally my old APE block gets some action! Glad to hear everything worked out for you in the long run
