Few pics of new custom kit.
Old Sep 2, 2004 | 03:28 PM
MYTURBOT/A's Avatar
Default Few pics of new custom kit.
Well here's a few pics of the new kit i'm making. Got most the exhaust piping done but I need to wait to get my T76 back from getting freshened up to make the down pipe and the rest of the exhaust. I'm using stock 00 manifolds facing back. 2.5in piping off the manifolds then Y'ing into a single 3in pipe about 14in before the turbo.
Here's some more pics with my old 60-1 mounted up. and where I cut out to tilt the radiator upright some.
Old Sep 2, 2004 | 09:16 PM
slow's Avatar
Looks good.
Should be a nice setup once done
Ryan
Old Sep 2, 2004 | 09:19 PM
Drake's Avatar
How are you going about bending and making all of your plumbing?
Old Sep 2, 2004 | 09:41 PM
MYTURBOT/A's Avatar
I went out and bought a bunch of U-bends and just cut them at the needed angles. Thanks Ryan we'll see how it performes if the weather ever stays decent for more then a week.
Old Sep 2, 2004 | 09:52 PM
Drake's Avatar
What kind of welder are you using? Also, what kind of pipe? Looking good so far, BTW.
Old Sep 2, 2004 | 10:30 PM
MYTURBOT/A's Avatar
Thanks, I'm just using a standard 115V wire feed welder. The piping is mild steel but it's thicker then normal stuff Don't know the gauge but it's about 1/8in thick.
Old Sep 2, 2004 | 10:45 PM
Drake's Avatar
Come to think of it, I seem to remember someone saying that Harlan made his headers by hand... I wonder if he did it this way? I'd like to make a turbo setup for my car, but I'd rather have stainless. Do you know if it's possible to buy pre-bent stainless?
Old Sep 2, 2004 | 10:55 PM
MYTURBOT/A's Avatar
There's tons of shops that sell prebent stainless. Stainless works on of the sponsers here does.
Old Sep 2, 2004 | 11:25 PM
Drake's Avatar
I'll give S.W. a look. What kind of shops would be best to check with? Exhaust and muffler places? Where did you get yours?
Old Sep 2, 2004 | 11:46 PM
BIGBOS's Avatar
Looking good so far
What kind of power are you expecting and at what PSI
Old Sep 3, 2004 | 04:55 AM
smokinHawk's Avatar
you can do a search of "mandrel bends" there was a good thread of alot of places that sell them.
looking good, we're all eager of the results. good luck.
that K member looks like it helps a bunch too.
Old Sep 3, 2004 | 07:33 AM
MIGHTYMOUSE's Avatar
nice job, good luck on completion.
where is the downpipe going? out pass side?
Old Sep 3, 2004 | 08:31 AM
Tiago's Avatar
looking good. I was gonna say , the welds look like some of my first when I started welding my own pipes at home hehehe. Is the piping coated or is that BBQ paint?
Old Sep 3, 2004 | 09:34 AM
Guido's Avatar
www.burnsstainless.com
www.stainlessworks.com
www.proturbokits.com
all places you can get u-bends in stainless or mild steel. Pro Turbo Kits sells mild steel u-bends at a pretty good price but with steel prices being so volitale, I wouldnt wait long if you are serious about purchasing materials.
Old Sep 3, 2004 | 09:43 AM
granitemonkey's Avatar
Its all starting to come together for you.
Old Sep 3, 2004 | 10:31 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Looks nice. Can you still remove it without cutting it apart?
Aftermarket k members do free up a lot of space.
Old Sep 3, 2004 | 10:32 AM
Tiago's Avatar
thats what I was thinking too. Makes me wanna get one and redo my setup
Old Sep 3, 2004 | 11:47 AM
smokinHawk's Avatar
speed inc has a GP for them at $375 (normally $440)
you cant beat that witha stick.
Old Sep 3, 2004 | 12:12 PM
MYTURBOT/A's Avatar
I'm hoping to make around 650rwhp with 13-14psi when it's all done.
All the piping is painted with ceramic header paint that is suppose to be good up to 1200*F, i've had a couple freinds that have used it with good luck so we'll see how it works.
The DP is gonna run under the K-member on the pass side or if I decide to remove the A/C I'll run it through there, but since I live in florida I want to try to keep the A/C.
I was hoping to have it done this week but between huricane charlie and now francis it's really messing with me getting it done. The power was out for a week last time, now this time I expect it to be out atleast the same amount of time if not longer.
I just ordered a set of spal 11in pushers to put in front of the radiator you guys think thats gonna be enough to keep this thing cool.?
Also what do you guys think about intake piping I was planing on running 3in but do you think I should go with somthing else? I have plenty of room for up to at least 4in piping.
Old Sep 3, 2004 | 01:22 PM
xfactor_pitbulls's Avatar
I like the setup. But if you are doing that much fab work you should fork the money over for a good 220 amp/gas shielded welder. The burn is so much cleaner and the hold last longer. Looks cool overal.
Brandon
