How does the LS1 handle Boost? ***pics***
Old Sep 6, 2004 | 06:42 PM
buschman's Avatar
Default How does the LS1 handle Boost? ***pics***
Well I took some pics of the cylinders today to show how the LS1 holds up to a year and a half of boost on a home tune(no dyno time as of yet).
A little bit of carbon build up, but the ringlands looked in good shape. In general the car ran an average of 5 lbs. When I first got the procharger on I would see 8#s. But after a while belt slip issues kicked in and I couldn't get more than 5#s. With the past few months I got the SDCE spring tensioned pullies with fixed all the slip problems. With the 3.7 pully I've seen 10#s on an accident by ~5000 RPMs. There has always been fuel issues with this car. It's boost referenced yet the FP stops climbing with the boost around 4-5#s. So on top of everything else it would run lean at WOT. With all those problems I was a little worried when I took the heads off. But I was pleasantly surprised when I saw how well the stock pistons had held up to the boosted and lean environment.
Let me know what you guys think.
Mike
Old Sep 6, 2004 | 07:15 PM
Gary Z's Avatar
I think I see evidence of PV contact in cylinders 2,3 and 5. Thanks for interesting info.
-Gary
Old Sep 6, 2004 | 07:17 PM
NJSPDER's Avatar
is that a burn on #5 on the left hand side of the piston?
considering the history of fueling issues and the fact that they are cast pistons i would say you came out pretty good. did you happen to do a compression test on it before you pulled the heads to see if teh rings were still all good?
later
tim
Old Sep 6, 2004 | 07:43 PM
buschman's Avatar
-Gary
Yeah I agree with that. Not sure what the contact means. I was thinking that the carbon buildup can create an extra layer and that layer closes the gap between piston and valve. Perhaps this is the infamous piston slap everyone complains about. I know I have it.
MIke
Old Sep 6, 2004 | 07:46 PM
buschman's Avatar
later
tim
Sorry I didn't do a compression check. As for Piston #5, I don't see anything out of the ordinary, but I'm no piston pro. The carbon build up seemed pretty uniform across all 8 pistons.
I did notice on the heads, the exhaust ports and spark plugs were slightly white, while the intake port was black. I know white is lean, but it waqs wierd how only the exhaust port and plugs were discolored.
Mike
Old Sep 6, 2004 | 08:25 PM
kp's Avatar
kp
You are definately hitting a few pistons with the valves, may be floating them or did a 3-2 misshift and whacked them at one time or another. Dont know what cam/springs you have but if its stock it was a misshift most likely..
Old Sep 7, 2004 | 02:05 PM
NA$TY-TA's Avatar
Looks like you cracked the piston in this pic
Same thing i did...... was she chugging a little at idle or whits smoke out of the oil fill?? What ya got planned now???
Kyle
Old Sep 7, 2004 | 03:56 PM
1F8TL02WS6's Avatar
that sounds about right.
Mike remeber the night going down georgia ave to ledos with anthony and eric? the 1-2-3-2 shifts with tam in the back seat? thats when u were also seeing 8lbs aswell.
-Danny
Old Sep 7, 2004 | 04:13 PM
buschman's Avatar
Kyle
Yeah in the pic that looks funny, but I think that's just a wet spot from the coolant. I ran my finger over that a million times and there's no crack there. Plus in normal light you can see it's just a wet spot. You'll notice #6 looks like it has a similar crack, but less so cause it's dried more. But so far no white smoke. I blew the dipstick once, but that's the only bad indicator I've ever seen.
Mike
Old Sep 7, 2004 | 04:17 PM
buschman's Avatar
-Danny
Yeah I remember. There's been about 3 or 4 times it's happen at WOT. one time at MIR I did it so bad that the car sounded like it blew apart and then cut off. I rolled through into the return lanes with the engine off. Tried starting her up, and much to my surprise, she started right up and purred like a kitten. I was really scared when that happened. Went right out the next day and bought the Pro 5.0.
Mike
Old Sep 7, 2004 | 04:28 PM
PHANTA-Z's Avatar
Mike
Been a many 'a shifter sold for just that reason. I know my mine was.
Old Sep 7, 2004 | 04:35 PM
00Pontiac's Avatar
how many miles on that engine?
Old Sep 7, 2004 | 05:03 PM
mi021le's Avatar
damb mike. i also thought they would look worse. happy u came out on the good side also. how long u having it down, whats the plan now?
Old Sep 7, 2004 | 05:14 PM
parish8's Avatar
single digit dreamer
i have about 2500mile on my set up. never less than 10psi and as much as 17psi(at least 30 1/4 mile runs at 17psi). so far so good, using good gas and pleanty of it. stock cast pistons. these things seem to be insanely strong.
Old Sep 7, 2004 | 05:32 PM
02BlueFirehawk's Avatar
why you prying the puppy open... hmmmm? hehe.. :sneaky:
Old Sep 7, 2004 | 06:01 PM
1dirtyZ's Avatar
don't jinx yourself parish
buschman, its nice to see that the rear cylinders (8-7) don't show signs of "leaness".
so why are you taking the heads off??
Old Sep 8, 2004 | 12:01 AM
buschman's Avatar
36K, 8K under boost.
I have the heads off so I can put the stock 6.0L heads on to help with compression and detonation.
Mike
Old Sep 8, 2004 | 08:59 AM
S_J_H's Avatar
Well you can't tell much about a piston with only the heads off. They have to be removed from the motor.
I have personally had 5 cracked pistons,my ls1 and old 5.0 combined, that looked perfect from the top and once removed from the bores the ring lands fell apart into my hands.
The best tell tale would be some heavier scoring on the cyl walls and usually the cyl will compression check or leakdown poorly.
But sometimes the ring lands just crack clean and the bores hold the piston together for a while and you really can not tell until they decide to go by-by for good.
Steve
Old Sep 8, 2004 | 11:55 AM
buschman's Avatar
Steve
You're probably right. I wasn't trying to say that everything is all fine and dandy. Just encouraged that the top side was holding up so well. As for the cylinder walls they looked and felt perfect. All of them had a nice criss cross pattern and no visible or tactile vertical lines.
Mike
Old Sep 8, 2004 | 12:04 PM
kp's Avatar
kp
After heads/cam/6speed, blower, then blower with nitrous and then back to heads/cam nitrous, 580 passes and very careful tuning my stock pistons held up just fine.
Well, almost, until the last pass with the nitrous and the piston broke, piston pin siezed and cracked the block (sleeve) on number 7
