Turbo 403ci with hyd cam= 1329hp flywheel
thanks for the info.
how are you keeping the heads on? what kind of head gasket ? bolts / studs?
is the block or are the heads oringed ?
rod length?
what type of rings did you use and what bearings did you use?
sorry for all the questions, its just amazing what you are doing with these motors!
oh, and how about some pics
rod length?
how are you keeping the heads on? 1/2 ARP studs what kind of head gasket ?Copper. bolts / studs?
is the block or are the heads oringed ? Heads have o-ring/ block has receiver groove.
rod length? 6.125
what type of rings did you use and what bearings did you use? Speed pro "hellfire" rings. Clevite main Federal Mogul rod.
rod length? 6.125
Kurt
#40
Originally Posted by 427
Yes this fits a F car.
All plumbing was done by the car owners.
Kurt
Kurt
Kyle
