Turbo 403ci with hyd cam= 1329hp flywheel
#44
Wow that looks like a fairly simple yet effective design!
Are they truck manifolds from a 6L or something? Could you have the same clearance with 2000 and up F-body manifolds?
Cant wait to see final pics!!
#46
rice_etr put some 2000 up headers on his custom kit, think he had to clearance them though.
#47
Originally Posted by smokinHawk
they are the 6.0's i believe.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#49
Super Moderator
They are 6.0L manifolds and the only clearancing is for the steering knuckle. A solid piece was made for this because the factory piece is partially plastic and would melt. Otherwise, a tubular K-member with tubular mounts and a home-fabbed motor plate. Trust me, this is no "bolt-in", and the guys that did it put lots of time into it.
#51
Another note that is of some interest.
When we first hooked up the boost controller the lines were reversed causing a massive overboost. So here are some numbers from 5000 rpm at 36psi!
1594 ft lbs@5000
1517 hp@5000
Not sure how long it would hold that level but it sounded cool!!
Kurt
1594 ft lbs@5000
1517 hp@5000
Kurt
#52
I am old. Thats where we always put them!! Nobody sent me the memo!!
Kurt
Kurt
Originally Posted by MIGHTYMOUSE
lol yea whats up with the turbo up there.. thats not cool anymore.. old school
#53
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#54
1594 ft lbs@5000
1517 hp@5000
Kurt
1594 ft lbs@5000
1517 hp@5000
Kurt
sounds like it was hooked up right to me.. put it back and don't puss out this time
#56
when i did some um research fitting the 6.0's cleared no problem. the only thing was on the passenger side the bolts would hit the steering line so it would have to be moved.
one theing i know they wont flip upside down cause the shock towers arnt wide enough.
i had some pictures but my home computer hard drive crashed.
#57
Originally Posted by Rick C5
Good numbers, makes me wish I had enough money to finish mine.
I have the same story. I have all the parts for my turbo kit and enough money to buy the rods/pistons and rings/bearings but then I still need a fuel pump, injectors, Big Stuff 3. I wish I could find a sponsor for this ****. LOL New job may be coming my way in which case the Sponsored by Self Racing could get a leg up but nothing is set in stone. LOL
#58
#60
First let me say that what ever this motor goes into is gonna be fairly quick.
The guys at W2W kick ***.
Now onto the 6.0 manifolds. They can be used with no clearancing of anything. The alternator has to be relocated up top and new custom power steering lines have to be made. I'm in the process of doing all this now on my CE. The stock steering knuckle is filled with rubber/plastic on the bottom joint. This ends up less than an inch from the manifold. We just bought solid steel U-joints and made a new shaft. Do not use the stock shaft the manifolds get way to hot.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
