Turbo 403ci with hyd cam= 1329hp flywheel
#81
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Originally Posted by 427
Not done on dyno yet. Todays session finished at 23. psi.
peak tq 1138@ 5400rpm
peak hp 1329@ 6400rpm
More to come......
Kurt
More to come......
Kurt
#82
Awesome..wow
Is anyone thinking about a bolt on turbo kit that bolts to a customers motor with those truck manifolds and aftermarker k-member..I guess the flange, turbo, intercooler, wastegate and downpipe..that would generate alot of interest at about $2-3k.
#83
Well with the 01-02 manifolds bolted backwards, couldnt U run piping where the battery is to keep the temps away from the motor???? I have been trying to find more information on the backwards manifolds??? isn't there a guy in Houston who did the backwards manifolds w/twin turbos on a LQ9 motor in his F-body????/
#84
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#88
Intake lift .610, duration 242@.050
ex lift .605, duration 238@.050
lobe seperation 115
Kurt
lobe seperation 115
Kurt
Originally Posted by MIGHTYMOUSE
to any involved.. are the specs for the cam available or pm me or even a rounded figure?
#89
Under criminal investigation for fraud
Kurt,
Do you know how much boost they were running at M9? Just trying to gauge how hard they were pushing it. I would think that they still have a lot left in it. That car should be pretty serious.........I think that they are sand bagging a little
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#90
They are not sand bagging. The converter was tight on there last engine so they had it loosened up, the things too loose now(6200+-). I think it was staying around 15-16 psi. They are on a steep learning curve and doing well. There is alot to learn on those cars as you know!!
Kurt
Kurt
Originally Posted by Chris@AP-Engineering
Kurt,
Do you know how much boost they were running at M9? Just trying to gauge how hard they were pushing it. I would think that they still have a lot left in it. That car should be pretty serious.........I think that they are sand bagging a little![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#92
Not sure what info you want.
4.005 bore X 4.00 stroke
Mahle custom piston made for us
Customer supplied LS1 callies rods
Callies crank
W2W girdle system on mains
Aluminum LS1 heads (customer supplied)
Comp R lifters
Cam Motion hyd roller
Jesel adj rockers
ls6 intake
Ported F car throttlebody
160 lb hr injectors
Big stuff 3 controller (this is highest HP coil on plug we have ever done)
Truck coils
W2W ported oil pump
Dailly scavenge pump
ARE 2 stage drysump pan
Garrett 88-98mm turbo
Honeywell air to water intercooler
The pricing on these engines is per customer requirements. I don't have a blanket price.
Kurt
Callies crank
Comp R lifters
Jesel adj rockers
ls6 intake
160 lb hr injectors
Truck coils
W2W ported oil pump
Kurt
Hey Kurt, why do you use truck coils? With ronnie's car you had a distributer, correct? Why did you need to run a distro with ronnies car but are running truck coils here?
Also what kind of block are you using? You guys are really doing some impressive work.
Mike
#93
lobe seperation 115
Kurt
lobe seperation 115
Kurt
Thank you.
#96
Word!
Originally Posted by Torquemonster TT
Kurt - the results you are achieving set you apart from the pack, and the generosity with which you share what most would consider their own intellectual property - is refreshing and inspirational, although I'm sure very annoying to those that are trying to protect theirs
- anyway - it is people like you that contribute to the greater learning of us all, and make advancements possible beyond the narrow confines of tunnel vision.
Thank you.
Thank you.
#97
We had some misfire problems with the FAST and stock LS coils above 6000rpm and 700hp. The truck coils got us above 900hp and 7000 rpm with no problems(still FAST). Ronnie's engine we needed 1200 hp and 8000 rpm so I was nervous about the ignitions ability to fire with the FAST controller so I built the dist set up.
Now with the BS3 I feel comfortable that it will fire the truck coils(8 amps vs 5 amp car coils) so that was used. I did first put my pick up truck engine on the engine dyno with LS coils from a vette and 21 psi we made 1050 ft lbs with stock coils/BS3.
The block is a 6.0 truck with some modifications to add strength.
Kurt
Kurt
Mike
Mike
#98
Gary Armstrong owns the company I deal with. They sell very nice dry sump pans. They also make a valvecover for me with spring oilers that fits over Jesel rockers.
Kurt
Kurt
Originally Posted by stealth
ARE 2 stage drysump pan? ARE is still in business? Wow, after so much bad business.
#99
Thanks Torque and Jammer. There are some things we can't tell you but we will share alot of info. Pushing the outer limits is always of great interest here. We will continue to find the outer limits of the gen 3 and 4 engine.
Kurt
Kurt
Thank you.
Thank you.
#100
Kurt
Kurt
