Another take on a FMIC install-pics
Oh yeah
the chop saw..that made my FMIC install a breeze especially with cutting the IC pipes.Here is the link to the Mandrel bent 3 inch SS pipes that me and kyle used
http://cgi.ebay.com/ebaymotors/ws/eB...category=33633
it says there is one left...but maybe you can email them and ask for 3....as that will the be the minimum to do the pipes......I bought two and had to buy some extra bends
Thanks for posting up how you cut the foam....that will be todays project.
J
It's all slowly coming together though.
Ok, Fog lights are installed. I like it a whole lot better with them in. I basically "minimized" the brackets so they would fit inside the fog light opening.
I'm pretty happy with how it looks now.
Just FYI, the pics of the brackets are comparing stock vs modded if I did not make that clear.
One hole is punched through the fog light tunnel in the front clip to mount the assembly. I don't have a tight right angle drill so I just heated a stubby phillips screw driver with a torch and melted a clean hole through the plastic.
Had to also cut the top of the bracket where the captured nut was for the aiming screw to be able to fit it nice inside the tunnel. So I just tacked on a small nut to replace it. But you could also just slot the bracket after cutting it and reuse the factory nut.
Steve
Have any pics of the cooler without the bumper?
Thanks
J
