Sts Turbo Dyno #'s Inside
Nice run, we'll talk more about this later but I thought I would post the following suggestions straight from the horses mouth (Rick Squires).
Here at STS we ran 5psi with the stock injectors on a bone stock car and put down 416rwhp. The stock injectors were probably running a little lean compared to your 43# injectors.
Remember Methanol displaces 2 psi and seems to be perform best after 7.5 psi. Essentially at 6.5 psi you were pushing as much air as at 4.5 PSI and with much richer settings. You still saw a gain to 420.2 rwhp because of the cooling effect. We usually run 8 psi with the methanol, using an EBC that switches from 5 psi to 8 psi while also arming the Methanol. With 8 psi and methanol we usually ran around 490-500 rwhp.
Next time why don’t you try running 8 psi and the methanol. Also make sure to check the following:
You should be running with the M10 nozzle (not the M15). Make sure your pump is the smaller pump with the 4.5" body(metal part) and not the 5.5" body. Your methanol mix should be between 50/50 and straight methanol.
We'll talk more later.
Visszont!
Thanks for any info you can donate.
Paul
We still have a lot of guys running on the stock fuel system with out problems but thats at 5psi and when they do run 8psi it's on the methanol. STS doesn't sponser LS1Tech but if you guys have questions and you're in the NE call me.
Yeah, I actually lost 2psi aprox. after the addition of the IC. Normallyyou wouldn't notice it I assume on a turbo car due to the waste gate making adjustments but on my kit the wastegate is BEFORE the IC so it doesn't know any better. before the IC I would see 6psi constant and after the IC with no other changes I could only get about 4psi, maybe 4.5psi best (not counting shift spikes). Hawk179 saw the exact same effect on his STS kit with the same IC on his Firehawk so I feel pretty confident that it is about a 1.5-2psi drop through the IC.
I am gonna try and retune this weekend and start using the methanol too. I'll definately let you know what I find.
This is my old dyno on the GT35 on my 5.3L truck
BT, was I too vague? LOL
The inj. are 42lb injectors.I must have been
when I posted that.
