Sts Turbo Dyno #'s Inside
Old Sep 13, 2004 | 10:12 PM
GONEB4U's Avatar
Default Sts Turbo Dyno #'s Inside
I just came back from Eastside Performance. We were dyno tuning a 2002 WS6 Trans Am. The car is 100% bone stock besides the STS base turbo kit with a t-60 turbo and meth. injection.The only other thing we added to this car were 43# injectors to keep it safe. This car is an automatic with stock exhaust and cats.
At 5.5 # of boost the car put down 405.0 rwhp & 411.6 ft lbs of torque.
At 6.5 # of boost with some meth. 420.2 rwhp & 428.1 ft lbs of torque.
We will be going back to the dyno within two weeks. We will be trying more boost and less meth. We didn't have any smaller nozzles with us at the dyno to swap out on the meth.The problem we had was when the meth turned on it was just flooding in. The air to fuel ratio went of the chart to pig rich. We'll be straightening out our meth problems before going back to the dyno.On a good tune I'm very confident that we should see 450+ rwhp next time.
Old Sep 13, 2004 | 10:37 PM
Ferocity02's Avatar
Very sweet numbers! I love the STS kit more and more... now only if I can afford one
Old Sep 13, 2004 | 10:40 PM
Slowhawk's Avatar
LS1Tech Sponsor
Do you think after running this kit that meth. is even needed on 5.5lbs?
Old Sep 13, 2004 | 10:50 PM
GONEB4U's Avatar
Meth was not turned on until 6.5# of boost. The 5.5# numbers were obtained with 93 octane fuel and NO meth.
Old Sep 13, 2004 | 10:57 PM
Slowhawk's Avatar
LS1Tech Sponsor
Thanks
Old Sep 14, 2004 | 06:22 AM
DarkblueTA's Avatar
just asking, but if you have bigger injectors...why are you bothering with meth. Meth is for someone on stock injectors and running more then 5#.
I would keep off the meth if you have the 43(42?)# injectors in the car and setup correctly(Injector Flow Rate table) and then also have fuel delievered in the Power Enrichment Table. (Didn't mean to make you sound like you were a drug dealer ).
I'll be looking forward to the new dyno numbers. Good luck!
Old Sep 14, 2004 | 07:06 AM
F8L Z71's Avatar
12 Second Truck Club
He needs the meth for the cooling benifit at higher than 5psi....
5psi will put his IATs at about 140-150deg. 10psi will push you to 190deg or more.
Old Sep 14, 2004 | 07:58 AM
JERRY2500's Avatar
14 Second Truck Club
Nice #s, I'm thinking IC
Old Sep 14, 2004 | 08:44 AM
WS6snake-eater's Avatar
Has anyone tried using a FMIC on the STS kit? I'm thinking that would be the way to go, especially with the Hong Kong special that everyone has been getting in on.
Old Sep 14, 2004 | 09:21 AM
Slowhawk's Avatar
LS1Tech Sponsor
Already in the works for a GT70 Turbo we are doing.Would also like to put 1 on a 6lb kit so more timing can be run.
Old Sep 14, 2004 | 09:24 AM
F8L Z71's Avatar
Went from 240deg IATs at 13psi to 107deg. From 140deg IATs at 6psi to 80deg.......... This is with 70deg ambient temps.
Old Sep 14, 2004 | 09:36 AM
Did the FMIC adversely affect boost? If so how much psi was lost going through the FMIC?
Old Sep 14, 2004 | 09:55 AM
CHRISPY's Avatar
awesome!!
Old Sep 14, 2004 | 11:00 AM
Wildman's Avatar
Justin can correct me if I am wrong, but he told me when I asked thsi question that it surged at first until they routed a vaccuum line to the wastegate. Then boost was good and steady.
Old Sep 14, 2004 | 11:15 AM
Blackbird's Avatar
more accurately the stock signal for the wastegate is directly off the turbo.
thus when you throw and IC in front it has no idea you did and that there is pressure loss. take the signal from the manifold instead of the turbo and viola the wastegate does it's job and maintains the boost pressure you set.
Old Sep 14, 2004 | 11:45 AM
DarkblueTA's Avatar
Then intercool the bish....
Old Sep 14, 2004 | 12:05 PM
JoeDirt's Avatar
Can you post the graph
Old Sep 14, 2004 | 12:43 PM
This is looking very interesting.
Old Sep 14, 2004 | 12:46 PM
ws6-speed's Avatar
What was his baseline dyno?
My friends 02 TA WS6 auto baselined at 297rwhp. If 300hp is representative for a stock auto that is a 35% increase over stock (assuming a 18% drivetrain loss) which is right in line with what 5.5lbs of boost should provide. Great numbers and another notch in the STS belt for delivering exactly as promised.
Russell
Old Sep 14, 2004 | 02:07 PM
bradyb's Avatar
Jo'l napot kivanok!
Nice run, we'll talk more about this later but I thought I would post the following suggestions straight from the horses mouth (Rick Squires).
Here at STS we ran 5psi with the stock injectors on a bone stock car and put down 416rwhp. The stock injectors were probably running a little lean compared to your 43# injectors.
Remember Methanol displaces 2 psi and seems to be perform best after 7.5 psi. Essentially at 6.5 psi you were pushing as much air as at 4.5 PSI and with much richer settings. You still saw a gain to 420.2 rwhp because of the cooling effect. We usually run 8 psi with the methanol, using an EBC that switches from 5 psi to 8 psi while also arming the Methanol. With 8 psi and methanol we usually ran around 490-500 rwhp.
Next time why don’t you try running 8 psi and the methanol. Also make sure to check the following:
You should be running with the M10 nozzle (not the M15). Make sure your pump is the smaller pump with the 4.5" body(metal part) and not the 5.5" body. Your methanol mix should be between 50/50 and straight methanol.
We'll talk more later.
Visszont!
