FMIC's on LS1's..pics
I mounted the mesh with some epoxy, I just traced the plate cover outline on it with a sharpie(thick tip) and cut out 1 inch wider than the out line. I then molded it around the back of the opening, you will have to cut diagonal cuts in the mesh at the corners so it forms evenly around the opening. Take it out again, bend it down a lil tighter and then mount it again and put the epoxy around on the top sides and bottom, use as much as you think it will need. I made sure it had enough to cover the mesh without the mesh "popping through it" It's a pain but worth it. Patience is your friend doing this. Make sure the epoxy is getting thick before doing this as it will just slop out everywhere
No behind pics as I was high on epoxy fumes, and my nerves were frayed at the end of the screen install lol.
I'm at home now, i'll be here for an hour or two...have to deposit my $$ and pay my loan....easy come easy go....damn credit cards lol.
J
J
I like the mesh. I frequent the Home Depot Racers Supply quite often. Find lot's of good race parts there.
I'll have to pick some up as I feel this nice intercooler won't look so hot once road debris takes it's toll.
I may try making a removable aluminum frame for the mesh or even a bar or tube type grill. Maybe have it held in place with a few of those Plastic push pins from the inside of the opening.The hard part would be forming the frame precisely to the opening so it looks good.
Just an idea at this point..
Steve
Steve
Originally Posted by NA$TY-TA
Hey i know that 2nd pic..... that guys a a$$hole..... just kidding. Somewhere out there. there has to be a pic of a FMIC on a Camaro.
Kyle
Kyle
Originally Posted by libertine1015
Its a joke, some people use Gutter Guard for the screen. Home Depot is a Home Improvement store, not sure if they are in every state.
#32
Originally Posted by F8L Z71
Gotcha.. I use Home Depot for weird junk al lthe time, mostly for my Reef tank adventures but cars too. I just thought maybe they had some kind of weird specialty department. LOL
J
