Exhaust housing comparison
Old Sep 20, 2004 | 09:41 PM
EightBall's Avatar
Default Exhaust housing comparison
How would a .84 A/R T3 compare to a .68 A/R T4 in terms of spool time, exhaust flow, backpressure, etc.?
EDIT: bear in mind this is in a single application. A friend has tried to convince me that the T3 would be better because it would spool so much quicker, and since I'm only running 7-9 psi, it wouldn't choke off too badly. Any input whatsoever?
Old Sep 20, 2004 | 10:28 PM
Jammer's Avatar
PS, there is no such thing as a "mild turbo"
Old Sep 20, 2004 | 10:31 PM
EightBall's Avatar
I know
Old Sep 21, 2004 | 09:10 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
The T3 would suck, plain and simple on a 346. A .68 A/R T4 would spool just as fast and would not choke off as early.
Jose
Old Sep 21, 2004 | 11:44 PM
Jammer's Avatar
A t3 in a twin kit..okay...single...no way, unless its a DSM.
Old Sep 21, 2004 | 11:49 PM
EightBall's Avatar
Thanks, thats what I thought too...
Old Sep 22, 2004 | 04:59 AM
smokinHawk's Avatar
a .84 will be to small (unless a rear mount), not to mention how bad a .63 unless you were using two of them.
id try to stay about a .96AR, my T76 would bet 10psi by 2700rpm so spool time wasnt bad at all.
Old Sep 22, 2004 | 10:39 AM
EightBall's Avatar
this is on the T4 housing Im assuming you mean?
Old Sep 22, 2004 | 11:14 AM
LS1TECH Sponsor
Yes, a T76 can not be had with a T3 unless someone is willing to cut the wheel down....not sure why they would...hehe
Jose
Old Sep 22, 2004 | 12:14 PM
smokinHawk's Avatar
the turbotech small frame T76 to help with clearance issues i assume.
