Need Proper Break-in Procedure for new APE Motor
What do you say?
- Dug
If you are going to tune it run it on the dyno and different RPMs and let the rings seat. Your going to be at WOT after that. She'll be broken by then.
If you put install it and break it in on the street for 500+ miles I believe you run a greater risk of washing down the rings and hurting the motor if it's rich or even worse. At least on a dyno you can control the proceedure much better.
I can hardly wait to hear how it all works out for you Dug
I'm getting excited too . . . my limitation however will be the 42lb injectors. I'm hesitant to run the alky injection on the new setup, so I'm trying to sell both to get 60lb Mototrons.
- Dug
they pulled the fuel pump fuse
cranked the motor to get the parts all oiled up
put fuse back in
started her
idle for 10-15mintues to get temps up and make sure they were stable
shut car off - checked fluids
started back up
went for a test drive
mild rpm run - no wot - put about 50 miles on car
oil change
Why don't you call Chris @ APE and ask him? They built the motor and also have a chassis dyno. I am sure that they have a procedure that they have proven to work.
Chris told me to fire mine up and let it run....... he said within 10 min the rings will have seated......... He told me to get 100 miles on it before i put a little boost on it... and i put 700 miles and a oil change befor eit hit the track.....
370ci right Dug???
Kyle
Thanks Kyle . . . appreciate it! At what stage did you dyno tune it?
- Dug
Pm me.... ill answer all the questions you asked me before...........
Kyle
I would make sure you have a halfway decent tune on the fuel/injectors and then do the 10 minute thing. Rings don't need 500 miles to seat.
- Dug
Pull the fuel pump fuse and unplug the coil pack's. Crank the engine over till you get some oil pressure. Plug back in the coils and fuel fuse. Fire engine, let it warm up to open the t-stat, top off anti freeze. Shut car off, check all fluids, start car up and go for ride. When first starting car try not rev it up to much, just get it to idle. For the first 100 miles or so just vary your driving, no constant rpm. After that go have fun. Also make sure that your tune is good.....you don't want to flood your engine with excess fuel. Take it to the dyno and tune it. Call me if you need any help.
Thanks
BTW, old school thinking generally had to do with flat tappet cams. They needed a good break in before you abused them. Also older technology for rings took longer for them to break in.
Prostock, my Camaro will be a little shy of the 100 mile before boost break in by about 99 3/4 miles.
