Needs help w/ Cam Specs & Head Gaskets
Old Sep 26, 2004 | 06:39 PM
01Bird_of_Prey's Avatar
Default Needs help w/ Cam Specs & Head Gaskets
In the process of building a 408 9:1, CNC Heads, 205 intake, 165 exhaust, 66cc. Running a D1 SC -- not sure how much boost yet -- old set-up ran 11 psi.
Looking to make 800hp, if possible -- need to know if GM 6L ml gaskets will work or do I need something with a bigger bore? Also, what I have no idea what would be the best cam for this set-up.
Any suggestions?
Old Sep 27, 2004 | 07:00 PM
thanks for everones help.
Old Sep 27, 2004 | 07:17 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
800fwhp or rwhp?
Old Sep 27, 2004 | 07:22 PM
800fwhp or rwhp?
looking for rwhp old setup made 647 on a 75 shot & 11psi
Old Sep 27, 2004 | 09:50 PM
383LQ4SS's Avatar
The old setup was on a 346 motor as well as stock heads and a VERY mild cam. He is now going to a 408 with very good heads. I would help but I am clueless on a good cam choice for that combo.
Old Sep 28, 2004 | 01:27 AM
red90cobra's Avatar
I believe you can use those. I thinks that's what I used on my 406
Old Sep 28, 2004 | 05:08 AM
smokinHawk's Avatar
sure the 6.0 gaskets should work as long as you get the right bore size since your over boring the 6.0 block.
those would be my first choice.
not to sure on the cam
just depends on your driving needs.
maybe a 230/236-115 (just a guess)
