Initial dyno results for Magnacharged '69
Finally got things somewhat going and it put down:
506 rwhp @ 5500 rpm
501 ft-lbs @ 4500 rpm
The blower makes over 400 ft-lbs at just over 2000 rpm! damn
Anyways, I had some leaking header collector slip-on flanges and it was messing with the O2 readings (sucking in fresh air at the collector). So, we couldn't push it further. I'll get those slip-on crappers removed and weld the pipe up on Saturday and take it back for round 2 of the tuning.
I'm happy with 500/500, as it was my initial goal with this 93 octane tune. I'm thinking it could probably hit 530+ with some more tweaking, maybe more.
Boost was 8.5 psi indicated. Fuel pressure a steady 60 psi.
Details:
348ci LS6 forged shortblock. LQ4 MTI Stage 2R heads (9.5 CR)
230/230 .581 114 cam
Magnacharger kit with intercooler (based on new GTO kit)
1998 PCM
www.ExtremeG.net
So, drivability sucks due to tires rubbing. DOH!
Don't even have to see the gragh to know it has alot of power under the curve. Bet it's a nice flat torque curve too.
Cablebandit, I'm installing a 6-point cage and ordering some Bogarts. Yes, I do plan on hurting some feelings out there in this show car, especially when I add the nitrous.
