Shooting for 800rwhp
Old Oct 1, 2004 | 09:26 AM
Wicked_Hugger99's Avatar
Default Shooting for 800rwhp
Contacted Speed Inc today and Im about to get the Gen7 so i can up the boost from 10psi to about 18psi running 116 gas & a fast 90mm intake/tb. Do you guys think i can hit 800rwhp( 630rwhp now w/ 10psi and fast 78mm setup on 104 gas) and run mid 9s with some practice( thats my goal) w/ a 6sp? I have all the suspension stuff i need. Thanks for any input
Old Oct 1, 2004 | 10:33 AM
smokinHawk's Avatar
mighty mouse hit 9's with a hair under 800rwhp so you should be able to it your weight is the same.
you should be able to hit 800rwhp as long as the boost and tuning is ther i dont see why not.
Old Oct 1, 2004 | 10:42 AM
stealth's Avatar
I made 817 rwhp and 790 lbs torque (corrected) in August on my 414 LS1 with a YSI and 14.5 lbs. boost on 100 octane. I've sold the car. So your 800 rwhp goal might be achievable.
Old Oct 1, 2004 | 11:36 AM
cool. thanks guys, just wanted some opinions from the good folks on here
Old Oct 1, 2004 | 12:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I hit 746rwhp thru an unlocked T400 vs your 6 speed, so I'm sure you can.
I'm going for 800rwhp too.
Old Oct 1, 2004 | 04:31 PM
Sweet PSJ! wanna race afterwards even though ull win!
Old Oct 1, 2004 | 04:35 PM
LS1Tech Co-Founder
Sure what have you run so far?
Old Oct 1, 2004 | 04:41 PM
MIGHTYMOUSE's Avatar
hugger a 9.5 would put you allmost .4 quikcer than anyone has ever rowed a f body ls1 to in the 1/4 if that gives you any idea if youre goals are going to be easily attainable or not.
what have you run so far at the 630rw level? what 60's can you cut?
i think 800 is do-able sure.
Old Oct 1, 2004 | 08:38 PM
I thought Harlans buddy ran a 9.44 in a 6sp, Taner i think. Havent run it yet...no seatbelts, got leaded fuel and it ate up my O2s, this and that but its going back to Speed Inc soon so i prolly wont run it till i get it back. I guess i just wanna run a solid 9 maybe 9.80s
Old Oct 1, 2004 | 08:40 PM
C5kid's Avatar
check out the FI forum on corvette forum, there is a guy running a F1R head unit on a 346 forged bottom end maken 836rwhp 12# boost...
Old Oct 1, 2004 | 09:28 PM
taner is lt1
836 at 12psi must have some unreal cyl heads and camshaft... what does the car run?
Old Oct 1, 2004 | 09:33 PM
Bryan Wilkinson's Avatar
I hit 800 RWHP and 753 RWTQ with my 427 and 10psi F1 Procharger
Old Oct 1, 2004 | 09:55 PM
C5kid's Avatar
sorry i was wrong it was 790rwhp
http://forums.corvetteforum.com/showthread.php?t=893953
that is the thread
Old Oct 2, 2004 | 12:37 AM
taner is lt1
Didnt know he was runnin an LT1 but still thats badass for a 6sp LS or LT
Old Oct 2, 2004 | 12:39 AM
Id love to still use the stock pcm but Speed Inc says i need a gen7 for those kinda numbers. Howd you do it? (not being a smartass, just curious)
Old Oct 2, 2004 | 02:37 AM
ls1 1990 VN's Avatar
PLAN B is a member of this forum, a couple of days ago i read on an aussie forum, he,s an aussie that his street car has just made 600+rwhp on a 346ci forged block, ported heads,a new proto baby cam, 10psi on a small power dyne blower.
Old Oct 2, 2004 | 07:17 AM
He do it pump gas?
Old Oct 2, 2004 | 07:25 AM
Havent run it cuz of a few minor probs that keep poppin up so ill prolly wait till after i get it back to make some passes it it. Been running my Z28 mostly. Tryin for high 11s in it. Im sure the way my SS is now i might crack a mid-high 10 but hopefully high 9s after. I gotta get used to a 6sp again as i havent driven it but 60-70 miles in the last 4 months and when i play around in it i usually go from a 5mph roll. I tried 1 launch on the street and it was all over the place. I know Im gonna need alot of practice but eventually Im gonna go w/ a th-400. then i might be able to keep up with ya.
Old Oct 2, 2004 | 10:22 AM
LS1Tech Co-Founder
Futral went 9.88 with his 6 spd LS1. That is the F-Body LS1 record. MMouse is #2.
Old Oct 2, 2004 | 12:23 PM
CHRISPY's Avatar
that was with nitrous, a WHOLE other ballgame from a six speed turbo setup.
His power all comes on within a 200rpm window. You have to worry about boost off the line, boost loss between shifts etc.
Taner can also drive like a **** with a six speed
Its going to be really tough with a six speed to run 9.4s with 800RWHP.
