Looking for cam options for my TT427!
The motor is a 8.6:1 compression motor fed with two T60-1 (T4/T4) turbos setup for 15-20 lbs of boost. All this boost is getting stuffed through a sheet metal intake and exhaust is a healthy 3". Heads are the AFR 225 with Inconnel valves and good valve job
I was thinking of a cam with 242/238 on 115 LCA and lift in the .610" range. Anyone else with a similiar setup?? Open for opinions!
Josh
