Tommorrow She Goes In The Car
Our B&M Saturday Night Special Converter
Deadenbear Powerglide by Hutch's Transmission
A higher than stock stall speed as delivered by the Holeshot converter will provide several advantages and benefits in vehicles with modified engines. Many modifications, particularly big cams, tend to reduce low end power and torque. The high stall converter allows the engine to launch the car at higher rpm where more torque is available. The Holeshot is generally a very good choice for the typical street machine that is looking for better launch capability and more strength. Street rods with modified engines will also benefit from a Holeshot converter. If your vehicle is equipped with a plate type nitrous system, you will need a Nitrous Holeshot!
Stall speed listings are based on engines producing 230lb. ft. of torque at 2,500 rpm. More torque at 2,500 rpm will give you more stall speed, less torque at 2,500 rpm will give you less stall speed than the stall speed ratings indicated.
Cheers,
Mark
If you are interested, here is a article on this setup w/ carbs and what is required to make it happen.
http://popularhotrodding.com/tech/0409phr_gmpp/
Looking at these pictures, I only have one question. How are you going to get the plumbing on the intake side of the blower. And with the radiator sitting right there, it is going to heat the plumbing and in turn heat the incoming air destroying all of the effort made by the intercooler.
I have the same problem with my blower, It sits right in front of the radiator.
What made you use that manifold. Was it to be different, or did you detect a benefit at higher RPMS
Thanks
Bryan
