Who's dynoed over 650rwhp with pump gas?
Read the Sig,
800RWHP, Stock Computer, 10#'s 93 OCT at BP. @ 5800RPM
Dyno Graph at www.perigee.net/~lunapark/800dyno.html
Passed NC Inspection.
Next Please.
Next Please.
Originally Posted by Bryan Wilkinson
Read the Sig,
Next Please.
Next Please.
C5R engines shouldnt be allowed in the poll
Check PM now, and try the new password.
What do you think the limit of pump gas is with a low compression 346ci?
Honestly, it really depends on the setup. If done properly, 18 psi should be no problem. You have to setup the supercharger and motor correctly though.
I was running mine up to 16 psi in june on pump gas without any detonation. I eventually backed it down to 14-15 psi when I realized I was 1000 rpm past my peak power.
Nice talking to you yesterday Kevin.
I will definitely keep your comments in mind regarding tensioners, but I first want to see what I can do on 93 pump gas (no alky) and then step it up.
8 second mod
PSJ, im sure Kevin could help out your needs. NOGO= very smart with this ****!
I saw him filling his car up this weekend to, i think the cheep basterd put in 89!!!
Originally Posted by NoGo
It worked! Thanks.
I had to, after I couldn't find a pump with 87
Actually, I just don't feel right putting race gas in a car that has been mostly constructed from Home Depot Performance Products.
Race gas or not, your car should be an absolute monster with that blower.
Originally Posted by 5-liter-eater
got any track times yet kevin?
However, if I did take it to the strip, I'm sure it would be nothing less than pitiful for a car running 700 HP. It should do well on the back strait though
To the disappointment of most of the guys at the shop, the car is built for lap times, not track times.
#36
Sounds like Bryan currently holds the record for most rwhp with a supercharged setup. Bryan what was the exact number your car pulled? I think stealth did over 860rwhp but that was with nitrous too. Who's done over 746?
