Your Fuel System Setup?
Anyone want to talk about their setups for 600rwhp+ ?
What problems have you run into, what have you added/replaced.
Which Rails and Regulators are you using?
At what power level did you need to replace them?
I plan on making over 600rwhp
Weldon 2025
Weldon regulator
83 lb. Siemens injectors
SS Racing fuel rails
-10 to front; -6 return
CAS Drag Tank
--------Going to:
2 Bosch 420L external pumps
No other changes
97/98 vette fuel rails with factory 1:1 regulator
Factory feed line
I used a feed line from my wrecked T/A as a return
2 walbro 340s intank
hobbs switch to kick on 2nd pump
Get GOOD hose...clamp everything...use good wire
Weldon 2025
Weldon regulator
CAS Drag Tank
--------Going to:
No other changes
How are you going to do the dual 420L externals??? Im wondring and i know Brian will chime in also because both of us are running a singal Bousch 420L external pump........
Now i am running
Sumped stock tank (98 Metal)
-8 to front; Stock feed as return
Into Na$ty Nate Fuel Rails.
Feed into pass side rail, with -8 crossover into drivers side rail.
-8 from back of drivers side rail into Aeromotive Rate Rise FP Reg. sitting on stock feed used as return
60# Motrons
Base FP set at 56psi.
Wanting to switch to
Use both -8an feeds from sump into to Bousch 420L side by side into a -10 Y-fitting.
New -10 as feed and use -8 as return. Use another -10 to dual -8 Y-fittings to feed the back of each Fuel rail.
Duel -8's back into FP Reg.
75# Injectors.
That should about do it.......
Kyle
I have the Bosch pump from my last setup where it was used as an inline with a walbro 340. I have a -an fitting on the outlet of the pump, but the inlet is just a metal nipple. How are you guys using this when attaching to your sumped tanks, or is there a different version of the pump with fittings on both ends?
Tom
I just installed the Racetronix 99+ system into my car. I looked in this thread because I'm planning to complete my system with lines and rails. Racetrnoix claims the pump can handle up to 700RWHP with no problem. I'm dropping 477/565 on nitrous and have pleeeenty of fuel left. I'm about to add another 150HP or so, but it 'should' be able to feed that as well.
Tom
I have that same pump on my sumped 98 metal tank now and im only using 1 of the #8 outlets with the other plugged. I am wanting to do the same thing you just wrote about Johns car with mine. I know Brian (BOS) will probably need the same thing when you guys start tuning his car in the next couple of days. Me and brian have the same setup except he has a F-1. would using my #8 line i use as my feed now be to much to use as my return? I do plan on running #10 line as my feed now. Do you think my 60# Motron injectors will be enough to support 650rwhp on a D1-SC car??
Thanks
Kyle
I guess we will find out if the 60's will hold up on Bos' car.
#10 return will work fine with a #8 return.
Tom
Tom
You dont think the single Bousch 420L will support the HP?? Me and Brian were talking and we were both worried about the pump.....
So what you are saying is that a big convertored car like mine (3500 stall) and big cam 230/236 .598/.608 114+4 will cosnume more fuel.????? Im hoping i have enough pump and Injectors.... Im waiting to see what Bos's car does so i have an idea what this pump and injector combo can do befor ei add anothe rpump and step up to a bigger injector. Thanks Tom
Kyle
Home made aluminum 10 gall cell in factory tank location
-12 feed to single Weldon 2025
-10 feed to Y block up front
-8 to each rail (Aeromotive 5.0 Mustang rails)
-8 from each rail to Aeromotive Pro-series regulator (Big silver one)
-10 back to the tank
96# injectors
Ran the car at 40 psi base, but ran out of injector at 20 psi boost. Upped the fuel pressure to 60 base, rescaled the injector table, but now I'm out at 23 psi
Spinning it to 8K RPM you've only got 15ms of inject time, and the 96's just can't do it.My 160's are freshly flowed and waiting for me to pick up at Kinsler, they left me a message today
3 gallon aluminum fuel cell
-10 prolite line to fuel pump
Magnaflow Pro Star EFI 600 fuel pump
-10 prolite line to front of car to
Aeromotive y-block
-10 to fuel rails
Wilson fuel rails
160lb/hr injectors
-8 Magnaflow EFI fuel regulator
-8 back to cell
We also are using Aeromotive's pre and post filters.
If I get enough cash over winter I'll plan on going to a BS3
