LS2 block for boost
First i thought you had an Iron block, did you get it sleeved or was i wrong and your running an aluminum block?
i talked to the engineer who helped devolop the darton sleeves and he seemed pretty confident of there ability, they use these on the highpowered import dragcars and top fuel dragcars running alot of boost and he said they dont have sealing problems
id either do an iron block or darton sleeved, i think its to early in the game to switch out an ls2, unless your into pinioering.
the only turbo kit right now that could support a big engine like your talking about is the TTi race kit, but you have to remove your AC
or a custom kit.
id encourage you to step to the dark side and go turbo!
big problem (well not that big i guess) is keeping the stock k-member its a real advantage in freeing up room for a real important Bigger downpipe. The downpipe size is very important.
for the HP levels your wanting you need at least a 3.5" which you cant do without a aftermarket k-member.
is the source you heard that they "shake more" acurate could you live with that?
you could just do a custom blower set up like PSJ too, he's making some good power
you can make 700rwhp with a 2.5" down pipe (Rob Raymer did on his old turbotech kit) its not the best way to do it, id think you'd end up hurting the motor.
so it can be down with a smaller DP, but its so much better with a bigger one (mmmmm, dreams of a 4" down pipe running through my head right now)
only modded supercharged car ive drove was my friends 96 LT1 vortech charged TA. the power band feels completly different, his would burn the tires off easier (maybe casue he had 3.73s) but my TA would pull the ***** off his car.
i could get on it easy, but when it would build full boost it would break the tires loose, you could definatly feel how much the turbo was adding power, his it just felt like it amplified the engines power at the rev level as the boost went up with RPM.
THe only thing id trade my turbo for is a bigger one!
Id give you a ride in my car so you could feel what a turbo ls1 is like, but im turboless right now, maybe you should hit me up next spring.
It looks like its real hard to find a good turbo kit or one that will work with big cubes, bout the only one out that could is the TTi race kit, but its expensive and doesnt keep AC.
