Sounds like a LS1 F-Body roots style supercharger might finally become a reality
#66
Originally Posted by 99Andrew
Okay, it's not a Magnacharger. Can we play a guessing game? Is this a project that Speed Inc. is putting together? I'm holding my breath....
#67
i would doubt it would be intercooled cause of the extreme space limitations, so far, nobody (besides whoever is doing this one) has been able to fit the S/C under the cowl.
#69
hmmm this is getting interesting....so its not Magnacharger.....
Here is a shot in the dark
http://www.holley.com/HiOctn/ProdLin...AMS/SC/SC.html
PM me if I am right
#71
[/paste]
The roots supercharger has been around for a long time, how is the Eaton supercharger different? The Eaton supercharger is essentially a Roots blower pump, with one substantial design wrinkle; each rotor has been twisted 60 degrees to form a helix. The two counter rotating rotors have three lobes, which intermesh during operation. These twisted rotors, along with specially designed inlet and outlet port geometry, help to reduce pressure variations resulting in a smooth discharge of air and a low level of noise during operation. This arrangement also improves efficiency over traditional Roots superchargers. With helical rotors and an axial inlet the Eaton supercharger can be spun to up to 14,000 rpm, thereby reducing package size.
http://www.magnusonproducts.com/faq.htm
question #3
#72
Have you ever seen the rotors on the inside of an actual roots style blower? The difference in that and an eaton based supercharger is exactly what they said, the original roots blowers don't have twisted rotors, the edges are perfectly straight whereas the eaton style have a 60 degree twist kind of like a twizzler.
-Sly
-Sly
#74
-Sly
-Sly
I figured it was a Magnacharger since he took the quote directly from their site
#75
That quote is from Eaton and is copied by all of the companies that use Eaton blowers. Doing a search on that quote on google showed that Yella Terra sells eaton kits too. Could this be the company?
#76
#78
Hopefully some sort of intercooling system will be integrated with the supercharger. I can't wait to see this thing come out. I think it will do good considering there seems to be a good amount of demand for it.
