Best location for the IAT
Old Oct 17, 2004 | 03:56 PM
tici's Avatar
Default Best location for the IAT
Where do you supercharged guys install the IAT?
Vortech want it before the SC, but I see many people having it after that.
To me it makes more sense if the PCM can read the real temperature and set fuel and timing on accord with it, but I guess Vortech did also some research...
Stefano
Old Oct 17, 2004 | 04:08 PM
slow's Avatar
Source, JerryW, the premier ford tuner
The air temp sensor MUST be moved, this is not an option. There are basically four things that control an engines likelyness to knock; Fuel octane (meaning its ability to resist autoignition), combustion chamber design, cylinder pressure and air temp. When you compress air, the temp goes up. If you don't move the sensor you have no idea how hot the air is going into the engine. If it's a 20F day or a 80F day, the temp of the air going into the engine, and thus it's timing requirements, change. Look at an '03 Cobra, Lightning, Roush StageIII, Saleen, even an old SuperCoupe, where is the air temp sensor? In the intake after the cooler. Why? Because you MUST know the air temp going into the engine to control the engine correctly. Now, some will say that the Cobra and Lightning have a sensor before the blower, they do. They also have one after...Every OEM does it on their blown cars, there is a reason for that and it's a good one.
Old Oct 17, 2004 | 04:22 PM
Another_User's Avatar
It only makes sense to put it after the supercharger, since the supercharger is going to significantly change the temperature of the air. You really don't want boost and wrong timing.
Old Oct 17, 2004 | 04:37 PM
Slowhawk's Avatar
LS1Tech Sponsor
We put them right before the throttle body on every kit.That way you can control timing if the intake temp gets too hot.
Old Oct 17, 2004 | 05:45 PM
tici's Avatar
Thank you guys!
It also makes sense to me... but why the hell does Vortech put it before the blower?
Right now we have 55F here, and guess how hot is the air after the blower?
The laser thermometer tells me about 100F, this at idle!
Old Oct 17, 2004 | 06:00 PM
slow's Avatar
vortech with the mail order tune from superchips inc is very conservative in timing,
I don't know why else they do that, but on the ford side relocating the act/iat sensor is the first thing a good tuner will do when they tune a blown car
Some reading/past threads on the subject.
http://www.ls1.com/forums/showthread.php?t=394382
Old Oct 18, 2004 | 12:59 AM
tici's Avatar
All clear! Newe hole is planned for today.
Thanks - Stefano
Old Oct 18, 2004 | 12:20 PM
tici's Avatar
Talking
Done!
Car runs the same but without the nasty 7-8 KR accelerating in 4th gear at 60 mph and the TCC locked
The outside temperature is 50F and after the SC I have now 90F.
I don't know if Vortech is compensating the wrong measurement with some other trick, but that KR was getting me crazy!
Thank you guys for the help
Stefano
Old Oct 18, 2004 | 01:08 PM
VortechC5's Avatar
With my Vortech I moved it into output side of the aftercooler. My car is an 02 which has the IAT built into the MAF. I bought the IAT and grommet for a 2000 Corvette, drilled a hole into the aftercooler ,and installed the sensor. It was an easy matter of cutting/rerouting the wires from the MAF up to the new sensor.
Stefano
Old Oct 18, 2004 | 02:00 PM
tici's Avatar
Vortech C5, Have you noticed some chenges?
As said, my KR is gone...
Old Oct 18, 2004 | 05:54 PM
VortechC5's Avatar
I have not seen any KR at all since relocating the IAT sensor.
