Got a question about a boost vs fuel..
Old Oct 17, 2004 | 08:55 PM
CountryMuzicZ28's Avatar
Default Got a question about a boost vs fuel..
If im WOT and the belt on the sc starts slipping would I see the fuel pressure drop a bit? I would think so since the air going through would be less.
Also the pulley setup I have is supposed to give me 10psi. The heads flow pretty well and I have a 2.75 blower pulley I would like to put on. Im not currently seeing 10psi.. The belt is slipping a bit though. I cant seem to find an 8 rib belt for the bigger pulley. I have the belt for the smaller pulley but I also dont know if my fuel system can handle it. Would you guys think that a 383 with trickflow heads with 8.5:1 compression and the 14psi pulley combo would be ok with a walbro 255 and a t rex boost pump with racetronix harness and 42lb injectors? The 14 psi is on a stock motor I should only see about 12 or so psi.
Old Oct 17, 2004 | 11:23 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
An Airtex T-Rex is apx. 200L/Hr and the Walbro is 255L/Hr.
The T-Rex will probably choke the Walbro!
If you need more fuel volume add a booster to the Racetronix PnP harness.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Oct 17, 2004 | 11:43 PM
BudH's Avatar
The fuel pressure won't drop, but the boost pressure probably will. When my belt needed tightening, the boost would rise to about 8.5 or 9 at about 5800, then quiver and drop back to 8 - 8.5 as the engine continued on to about 6400 rpm. After I retightened the belt, it continued on up to 9.5 or so and didn't drop back.
Old Oct 18, 2004 | 12:28 AM
im listening.. booster. where is that on your site? I cant find it on thunderracing either. Do you think 42 lb injectors will support a 383 with a mid range cam and 12 psi? 8.5:1 cr.
also.. according to my fuel pressure guage im seeing 50 psi @ WOT around 3500+ rpm.
Old Oct 18, 2004 | 12:36 AM
goober35's Avatar
I here about belt slipping on blowers all the time. I would think by now they would do a cross cut bell that goes across the pully and not the length ways on the pulley. Or is this out and it is just cost to damn much.
Old Oct 18, 2004 | 02:43 AM
wouldnt it walk off the pullley???
Old Oct 18, 2004 | 10:28 PM
goober35's Avatar
Not if the pulley had walls on it. I will try and scetch some thing. Think of it as a motorcycle belt. They dont slip off. But i am not sure on how fast the blet is going.
Old Oct 18, 2004 | 10:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What power level?
42's sound small.
I am not a fan of T-Rex inline pumps for your power level. I like what Jack @ Racetronix said he's the fuel system guru.
