Boost controller help
Old Oct 17, 2004 | 09:25 PM
SuperSporttruck's Avatar
Default Boost controller help
I am looking for a good boost controller. I am starting with a .4 bar spring at 5.8 psi and would like to use the controller to adjust up to 12 psi. thanks
Old Oct 17, 2004 | 09:28 PM
parish8's Avatar
single digit dreamer
i have a blitz electronic boost controler. it works great. clean and simple controler with lots of extra features if you ever want to figure them out. it was expensive, something like $400. you can get a manual controler that will let you goto about douple your WG spring and those are only about $50.
with the blitz i can shut it off for 7psi(wg spring only) and have had it set as high as 17psi
