Crank Pulley Removal
Old Oct 20, 2004 | 12:52 PM
IRVINEWS6's Avatar
Default Crank Pulley Removal
You guys that are changing your own crank pulleys, what tools/puller are you using?
Old Oct 20, 2004 | 01:19 PM
nbm00ws6's Avatar
The way I do mine is that I use a 3 jaw puller. I take the washers off the blue crankshaft bolt that came with the Procharger kit. I then thread the washerless bolt into the crank about 1/2 way. Then install the 3 jaw puller onto the three tabs located in the center of the factory crank pulley, and the center bolt of the 3 jaw puller on the blue crank bolt.It should now back off using the 3 jaw puller. I install the new crank pulley using the came blue bolt with washers added along with blue loctite.
Tom
Old Oct 20, 2004 | 05:32 PM
EightBall's Avatar
I used a 3 jaw puller with a 10", 3/8"-drive extension to get it all the way off
Old Oct 20, 2004 | 05:47 PM
SliverSS's Avatar
honestly..if you have the cash..by the ATI crank puller..it can save you A LOT of time and aggravation
Old Oct 20, 2004 | 09:23 PM
IRVINEWS6's Avatar
Thanks for the input, guys!
Will having an ATI damper make it any harder?
James
