Checking Options on Forced Induction
Old Oct 21, 2004 | 07:46 PM
computernerd's Avatar
Default Checking Options on Forced Induction
I'm checking my options on either a turbo or supercharger setup.
I'm looking to pickup at least 100hp on my weekend cruiser.
Motor has less than 8000 miles on a rebuild.
LT4 Hotcam Kit, New Timing Gear and Chain, Felpro 1074 Head gaskets, Keith Black Hyper. Pistons 9:5:1, high volume pump, Arp rod bolts. It has stock rods. The heads have been hand ported mildly. 30Lb Injectors, 52MM TB.
Other than possibly a bigger fuel pump I'm not looking to change much else.
I've searched thru some threads and see my compression is a little high, also Hotcam isn't a really good FI cam.
Taking all that into account:
Turbo or SuperCharger?
__________________
94Z28 A4 White T-tops, 355ci, HotCamKit, Accel 30#, 52MM TB, OTVC Taylors, NGKs, Edelbrock Headers, Borla, MTI CIA, 1LE Elbow, Gutted CAT, LT4 km, 160° hypertech, !AIR, !EGR, PCMforLess, Eibach SportLines
Old Oct 21, 2004 | 10:54 PM
SS2win's Avatar
man you should do a search... there is lots of comparisons and opinions here. That said, a turbo setup is the best choice but since you only want 100 hp then go with whats cheaper. All the negatives with a supercharger only come when you are pushing the envelope in search of more power.
