Hey guys, what do you think of this?
Old Oct 19, 2004 | 01:49 AM
omore001's Avatar
Default Hey guys, what do you think of this?
I bought my 02 Trans am the other day with the 6 speed and t-top. Not a WS-6 but the dealer gave a good deal regardless. Anyway I have a couple thousand saved up and was looking into forced induction with a conservative tune to not have to touch on internals...yet. I found a local shop that sells ($3500) and install ($500) a get this (Rear-mounted turbo kit) supposed to go where the muffler is found. The kit is set a 5psi and they claim 450hp to the wheels. They have some videos on the website + explainations. The kit does not include intercooler. I wanted to know what you guys thought about this whole gig. Is it worth it or do you think it is faulty and farfetched.
here is the website http://www.jlturbo.com/
Please let me know, your opinions will help with my choice.
By the way, I have considered a supercharger but the thought of a turbo trans am just gives me goosebumps.
Old Oct 19, 2004 | 01:55 AM
waterbug1999's Avatar
Try the search button and put in STS turbo.. Im sure you will find what you need...
Old Oct 19, 2004 | 08:23 AM
2002 Trans Am's Avatar
You'll find what you need plus 10 to the 2nd power multiplied by 3.67
A lot of info on that kit here. My opinion on the kit is that if it reaches your power goals, and you don't mind giving up your exhaust (which I am sure is the stocker so it doesn't matter) then yes go for it and build around the STS kit.
BTW I wanted a WS6 also, but could only find a new Trans Am in my area at the time and I was upset like you, but I came to realize the WS6 option is a waste of money IMO being that you came to LS1Tech you'll all of a sudden get the urges to change everything. And if you want a hood, American Sports Car Design "ASCD" (a sponsor to the right) sells the exact WS6 hood for 15% off.
Old Oct 19, 2004 | 09:32 AM
NA$TY-TA's Avatar
Do a search for STS Turbo and the the Angie..... And dont pay anyone to install it. It is very easy... just like putting a catback on and then routing some piping to the front. It can be done in your drive way in one whole day. Be sure to get it tuned also... or your stock motor will go..
Kyle
Old Oct 19, 2004 | 09:42 AM
If the install includes a tune, then $500 is extremely fair.
If not, then like Nasty said above, do it yourself, its incredibly simple looking
Old Oct 19, 2004 | 11:44 AM
omore001's Avatar
Hey thanks guys, you guys are really responsive in these forums. 02 T/A, the $500 install does include a tune. I think the price is fair, I just think the whole rear mounted turbo sounds a little weird. But hey, if they can pull it off...
By the way, I bought the car as a Certified used GM vehicle. I had a chance to look at the exhaust. The tips say Borla and the cats are closer to the hearders than my stock LT1 Trans am exhaust. Don't really know if it is a cat-back but it does sound slightly louder than stock and I am getting some backfire the first 5 minutes of operation on a cold engine.
Old Oct 19, 2004 | 12:09 PM
Sounds like a Borla system to me with stock manifolds. With the STS kit, you don't need that Borla anymore, you could probably sell it for a couple hundred bucks, not really sure what they go for.
That $500 sounds extremely reasonable, is it a dyno tune or a mail order tune...Either way its cheap, but dyno tunes are usually more effective.
BTW I paid $550 for my dyno tune alone, but I am in NJ where everything is more expensive
One last thing you should probably know: from my limited knowledge of FI, I have come to know that FI has a tendancy to break stuff, nothing major, just things like transmissions, rear end, and motors , but the STS does seem pretty conservative especially with its 5psi, so you should be ok for a long time if you don't go too crazy, but its always good to be prepared
Old Oct 19, 2004 | 07:17 PM
Koncrete's Avatar
he really should have to worry about breaking stuff until he decides he want a lower 60ft time! when your tires are spinning you ok, but when you hook is when your putting the most force on your rear end and tranny
Old Oct 21, 2004 | 11:37 PM
SSnakekiller's Avatar
You guys can check this out...should give you a little more recent info:
http://popularhotrodding.com/tech/0411phr_sts/
