Overlap question...
Old Oct 22, 2004 | 01:03 PM
RealQuick's Avatar
Default Overlap question...
Ok guys. i am gonna have a custom grind made for a turbo setup (probably rear mount homemade). I know the general trend is either single pattern or a reverse split duration. My question is how much overlap is too little or too much. Is -3 degrees gonna make more powertq than a cam with -1 degrees overlap? I know the rule of thumb is -6 to 0 degrees is where you want to be for turbo. So in general, what would be the hp/tq and powerband difference when comparing a cam with -3 degrees overlap compared to the same cam with -1 degrees overlap. Thanks.
