New STS Dyno #'s
Old Oct 30, 2004 | 05:48 PM
SSnakekiller's Avatar
Default New STS Dyno #'s
We did an LS1 STS install and tune on an otherwise stock 2002 WS6.
Before the turbo kit, the car had a lid and muffler.
Car has the following mods:
Z06 clutch
Car has fully stock exhaust system, manifolds, even CATS!
On a dynamometer (Mustang Dyno) it made 444RWHP, 514RWTQ @ 4750RPM and after that spun the tires hard so had to let off. Tried adding weight to rear but no luck. Clutch also starts to let go around top end.
Conversion factors between dynojets and dynamometers are generally pretty different, but the owner of the shop says for dynojet numbers you can add 15% of the HP and TQ made on his dynamometer to roughly get near dynojet numbers. I have personally seen the results from a friends Lightning on both dynos and it is about that.
To test this theory we will be getting it on a Dynojet soon. Will post back once we have results.
So lets see, Final Dynojet Result ~ 510RWHP/591RWTQ
This is at ~ 8.5psi on methanol.
He is extremely happy with the setup and should be getting to the track by the end of next week.
Old Oct 30, 2004 | 06:08 PM
F8L Z71's Avatar
12 Second Truck Club
Very cool Jesse!
Coul;d you please post o\up or PM me a dyno sheet and turbo specs? I have never seen one dyno'd with 8psi and meth
Old Oct 30, 2004 | 06:12 PM
i have the sheets and will scan them when i get time, but there is no AFR on the sheet which sucks.
Old Oct 30, 2004 | 06:54 PM
quicksilverado's Avatar
Great numbers. Which turbo was this with. The base turbo or the upgraded one.
Old Oct 30, 2004 | 06:58 PM
Base turbo...
Old Oct 30, 2004 | 10:44 PM
DramaFoYoMama's Avatar
How is a Z06 clutch holding that?
Old Oct 31, 2004 | 08:40 AM
CHRISPY's Avatar
Very nice
The stock exhaust setup (00 and up) should hold heat very well with its cast manifolds and steel Ypipe and intermediate pipe
Old Oct 31, 2004 | 10:06 AM
Reread post
Old Oct 31, 2004 | 10:14 AM
F8L Z71's Avatar
Originally Posted by Chris ARE 385
Very nice
I'm gonna try testing out wrapping my exhaust with header wrap all the way back and see if that helps any. Because of my turbo sizing I have terrible lag so anything should help.
I also notice that when the motor and turbo are cold the thing wont spool for ****. Once warm it's a night and day difference though.
Old Oct 31, 2004 | 12:51 PM
CHRISPY's Avatar
Thats a good idea. Should help a lot.
Old Oct 31, 2004 | 07:07 PM
CHRISPY's Avatar
BTW F8L Z71 are you the guy running the 4 inch exhaust?
Old Oct 31, 2004 | 07:23 PM
F8L Z71's Avatar
Nope, I'm all stock with gutted cats
Old Nov 1, 2004 | 09:56 AM
CHRISPY's Avatar
ahh ok cool
Old Nov 1, 2004 | 12:38 PM
NA$TY-TA's Avatar
Good Job man..... this is thru the new FMIC also correct?
Kyle
Old Nov 1, 2004 | 12:41 PM
Kyle
Nope, just methanol inj. I forgot to mention car also has 4.10 gear
Old Nov 1, 2004 | 01:12 PM
seal's Avatar
those are some wild numbers!
Old Nov 1, 2004 | 02:49 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
F8L, move to FL and that cold start thing will be fixed
Old Nov 1, 2004 | 05:33 PM
F8L Z71's Avatar
LOL, I wish it was just a temp thing bro.
