flat tops with forced induction?
Old Nov 2, 2004 | 01:08 AM
ECOJET's Avatar
Default flat tops with forced induction?
Hey ppl
Just got a technical question. I have a funny combination (not ls1 motor) anyway a good piston i have found that'll sit in a good spot in the block (20thou under deck) is a ross pistons and its probably the single best option available to me. The problem is its a flat top, but even with the flat top and valve reliefs it gives a ratio of around 8.8:1 which is exactly what i was after anyway. Most ppl always run dished pistons (mostly just to lower comp i guess)
Anyway the question is, given its a good compression (which it is) is there any problem with usiing flat top pistons in a blown/turbo combination?
Old Nov 2, 2004 | 01:21 AM
red90cobra's Avatar
I believe long as it gives you the same ratio your looking for it shouldn't matter. It doesn't compromise the piston. Shouldn't matter at all.
Old Nov 2, 2004 | 03:22 AM
y2khawk's Avatar
The main reason to use a dished/inverted dome piston versus dropping below the deck is to drop CR while maintaining the quench area. Or because the comp height on the piston is such that a good ring stack w/ a large top ringland just won't fit.
But even at .020 deck + a resonable gasket thickness you should still have decent quench. A little more distance than ideal, but ok none the less.
Old Nov 2, 2004 | 06:32 AM
Classic's Avatar
Just like Harlan said -- in an ideal world you don't really want the piston in the hole that much, so by going to a dished piston you can run the piston up further giving you a better quench without affecting the compression ratio.
Also, another benifit is that a dished piston is more "ideal" for combustion then a flat top (and certainly more than a dome!!).
Old Nov 2, 2004 | 07:23 PM
ECOJET's Avatar
thanks guys, good info.
