Back from the track
Old Nov 8, 2004 | 12:20 AM
LASTLS1's Avatar
6 Second Club Moderator
Good job Bos! It seems your going in the right direction. I set my shocks at 3 and 3. 14 psi and 27'' quick times. Dead hook off the trans break. Good luck. Andy. BTW my wheels were still slipping on the tires at 14psi. I have them screwed now.
Old Nov 8, 2004 | 12:43 AM
BIGBOS's Avatar
Yea, my wheels spun too, and I didn't even really hook it......tire still had some wrinkle in it though......
When you say 3 and 3 you had the rears at 3?
Old Nov 9, 2004 | 11:54 AM
RyanJ's Avatar
SSU Moderator
thats sooooo much work.
when does the turbo go on?
Old Nov 9, 2004 | 12:08 PM
kp's Avatar
kp
Thats awesome bos, didnt notice this thread until now. You should be able to get some 9's in good weather and a good 60'
Glad all the waiting and work finally paid off for you.
Old Nov 9, 2004 | 01:01 PM
LASTLS1's Avatar
Yes. I even went up to 5 and still hooked. But I only stall at 3200 so the launch is weak!
Old Nov 9, 2004 | 01:37 PM
NA$TY-TA's Avatar
Getter dialed in and lined up Brian...... You can do it...
Kyle
Old Nov 9, 2004 | 02:33 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sounds nice. On my 10.3 pass I went 105mph in the 1/8th but I did not go off the 'brake on that pass. The other folks who have gone high 9's have typically gone 110mph in the 1/8th.
Old Nov 9, 2004 | 03:02 PM
BIGBOS's Avatar
Yea, as soon as I get traction, a 6.3-6.4 is possible.....
I got a long, boring winter ahead of me
Old Nov 9, 2004 | 03:18 PM
Evil F1 SS's Avatar
I have a fun track filled winter ahead of me!
Old Nov 9, 2004 | 06:16 PM
BIGBOS's Avatar
Enjoy the texas heat
Old Nov 9, 2004 | 06:42 PM
Evil F1 SS's Avatar
I was here during the summer and to tell you the truth it wasnt much worse than Chicago in july & aug. It just lasts 2 months longer. Ill take 5 months of heat to have nmo snow ever!!!!! And mid 70s until dec and a cold cold winter of 50 degrees.
BTW- Ill have fun at a track thats at sea level
Old Nov 9, 2004 | 06:49 PM
  #32
BIGBOS's Avatar
Stop rubbing it in
Old Nov 10, 2004 | 10:35 AM
  #33
SDCE's Avatar
Default were you on the revlimiter at all??
Revlimiters are not our friend!!!
Another problem that we've seen come up is the head unit itself "shifts"...the shaft that the pulley is on can sometimes slide in and out. Check to make sure that isn't happening. We've seen that a few times...
Also...we have an F series head unit coming that we will be playing with on an LS1. Because the bracket design is different than the P and D series, our tensioner system may need some adjustments to work better with the different bracket design. BOS, because you're the first guy that has our tensioner on the F series, we'll work with you in any way we can to get it right. Is there anything we can do right now? Let me know...
Do you have any video of your track passes?
Old Nov 10, 2004 | 04:27 PM
  #34
BIGBOS's Avatar
I got no video at all.......
I need to shim the 90mm out close towards the motor, that will make the crank, blower, and 90mm pulley all perfect.......but the spring tensioner pulley will still be sitting back in its original position, any way around this?
If I got to move that spring pulley over some that would make them all line up......
