CP size on the new 8 rib ATI setup?
Old Nov 9, 2004 | 09:14 PM
LSs1Power's Avatar
Default CP size on the new 8 rib ATI setup?
I would like to know what is the crank pulley size of the new 8 rib ATI setup? My car has 4.25 blower pulley and its making 7.5psi at 6000rpm. Im guessing 7" crank pulley to give 7.5psi at 6000rpm on a cammed motor.
Old Nov 10, 2004 | 09:16 AM
Ponyhntr's Avatar
The crank pulley is 7.65 for the ATI 8-rib upgrade.
Old Nov 10, 2004 | 09:22 AM
BLWNZ's Avatar
Is it possiable to use this pulley instead of the stock 6 rib pulley and just not use the one rib. i am thinking this would work i just want a bigger crank pulley.
Old Nov 10, 2004 | 09:51 AM
Ponyhntr's Avatar
No, it will not work like that. For one, the spacing is different (i.e. the blower is spaced out differently). And two, the 8 rib pulley will only bolt to an ATI Performance Products balancer. It will not work with a stock balancer.
Old Nov 10, 2004 | 10:14 AM
BLWNZ's Avatar
Cool thanks for the info
Old Nov 10, 2004 | 12:10 PM
LSs1Power's Avatar
Thanks for the information man.
Old Nov 10, 2004 | 12:47 PM
Ponyhntr's Avatar
No Problem!!
