Need some help
Old Nov 11, 2004 | 06:19 AM
Proto X's Avatar
Default Need some help
I bought a QMP kit from a member here and have some questions.
1. I have no oil lines what do I need?
2. Where can I get the attachment that goes above the oil filter for the feed line?
3. Can I use stock exhaust manifold gaskets?
4. Does anyone have instructions for this kit? I have some but they are crap.
Old Nov 11, 2004 | 07:11 AM
cablebandit's Avatar
If it is like the turbotech kit, you need to tap the stock oil feed attachment....there is a blank pad there that can be tapped and a fitting inserted...dunno the size. The oil pan can be tapped at the front and a fitting installed there. Any hydraulic place can make you the hose that goes from the oil filter block to the turbo. The hose from the bottom of the turbo to the oil pan should be easy to find...prolly like heater hose or something
