Few Qs about ATI setups...
Ok..
1)
The pulley system thats offered with the ATI kits... Ive been reading that they have been improved on... how do they work currently? Does ATI offer a optional 8 rib when you buy the kit?
2)
SDCE.. I found their site.. but has a few dead links on it, including the one on the tensioner. How much is their 8 rib upgrade and is it worth it?
3)
ATIs twin SMICs... how well do they work? Is it worth it to upgrade to a single FMIC? I have a hook up on a FMIC that will work if I decide to go that route... will ATI sell the kit minus the SMICs?
4)
Will a ATI kit work with a ASP pulley? What do I need to retain the ASP pulley?
I think thats it... thanks in advance!
Oh yeah.. anyone have any ATI P1 or D1 dyno sheets I can look at? Thanks again.
The 8 rib is standard on the 1-DSC 8psi kit according to the sponsor.
Another company with same name 'ATI' makes a pulley and it can be undersized or standard. The ATI Procharge pulley bolts onto the ATI pulley.
2)
3)
4)
2. Just go with the new ATI 8 rib setup and u will be fine. I know few people who are running 15psi on it with no problems.
3. From what i have seen especially in the corvette forums they get up to 40rwhp gain just from chaning the intercooler setup when they are making over 500rwhp. If u are making less than that dont bother changing to a FMIC.
4. I dont think the 8 Rib ATI will work with the ASP. U can just sell it and get your self an ATI superdamper instead of it and u are ready to go.
Good luck.
They told u it will cost more because u bought the 6 rib already. Im saying if someone wants to buy a ATI SC now he will have the option between the 6 rib or the 8 rib at no extra cost. I bought my 8 rib ATI with no extra charge. Actually ATI made a mistake and sent me the 6 rib and when i called them about it... they sent me a 8 rib conversion for free since they made the mistake from the first place. What a great customer service.
LSs1Power... about the FMIC.. I should be making right at 500rwhp after the install. Im making at or a tad higher then 400rwhp NA.... do you think a FMIC would benefit me?
Don't blow up fool. I don't wanna hear you bitch. Hahaha
I think he will make more than 530rwhp with his setup running 8psi. Mine made 538rwhp running a really messed up AF (leaned out at 6000RPM) and really low timing. Mine was making 385rwhp 378rwtq before the 7psi and it made 538rwhp 482rwtq at 7psi at only 6000rpm. That is a gain of 153rwhp and 105rwtq not forgetting 500-700rpm still are not used and about 2 more psi to be had.
http://www.msnusers.com/CarsRelatedG...oto&PhotoID=54
This graph shows u the AF for the SC pull against the best pull before the SC.
http://www.msnusers.com/CarsRelatedG...oto&PhotoID=55
Looking at this AF there is alot of power left on the table, but we didnt bother tunning the car all the way because we needed injectors. The 42lbs were working over 100% Duty cycle. Also usually a SC will move your peak power up to 400rpm so we should have taken this car to 6700rpm. Im going to get an update when we tune the car again and take it all the way to 6700rpm. We are also going to try the cutout to see if we gain anything with a blower car.
It is a really good cam... drives like a TR224 114LSA, but it has a deeper exhaust note to it due to the 230 exhaust side. My car idles at 800rpm and had no problems at all. I gained 44rwhp with this cam N/A and now with only 7psi i gained 150rwhp which is really good especially with a untuned car. We are trying to finish the car this week, so i will post the final results when we are done.
U can check the dyno graph for the cam before and after. http://www.msnusers.com/CarsRelatedG...hoto&PhotoID=8
F8Lfoolio... I know it technically wont be a 400rwhp NA anymore after a new tune. I dont let everything you tell me go in one ear and out the other. Just some of it...
You SOB! LOL
If I move into this new condo I may end up puttin an STS kit on the T/A. Just a base kit nuthin special but you better watch out foo!
Dave's gonna get back to me on what kind of deal i can get.
http://www.ls2.com/forums/showthread...hreadid=136092
He bought this kit over the ATI for Vortech's rep of being reliable and he didn't even imagine of going over 600hp.
UMMM NOOOO
Dont do it........ ha ha
