what size oil line??
on my T76 i had i think it was a 4an line
a stock or ported oil pump should do fine
any post filter high pressure oil source will be fine to supply the turbo. -4 is about the right size you want. A turbo only needs a few GPM at most for proper lubrication. No need (from turbo supply point of view) to add a larger pump.
Make sure you have a large, free flowing return line back into the motor. Keep it above the oil level in the pan. I'd use atleast -10 on the return side.
