Took a ride in an STS car
Old Nov 22, 2004 | 07:39 AM
RealQuick's Avatar
Default Took a ride in an STS car
Well, I went for a ride in an Purevil/5litereater's sts car. Quick breakdown of the car:
LS1 Z28 6 speed
Forged block
LS6 ported heads
small turbo cam
9" rearend
STS with T70 and FMIC
At 14psi he is at 700rwhp. I believe he only had it set at 12psi when we ran. The car screamed and he only revved it to 5k rpm before shifting due to his oil pressure alarm going off. Full boost seemed to have hit just under 4000 rpm. With a decent size turbo mounted back there some lag is to be expected. Once you get out first gear lag becomes non-existent when the motor is wound up and the rpms drop for the next gear. All in all the kit is very clean and the car gets up and goes. It really sucks you back into the seat when that turbo spools up. For those of you on the fence about buying a clean, easy to put together kit, try and go for a ride with a board members car if possible. I am still going front mount with my T76, but I respect Mike's ride and am amazed at his power output. The car is a beast.
Old Nov 22, 2004 | 09:35 AM
bradyb's Avatar
Tell him to call us and we'll get him a larger oil pump. (801) 224-3477
Old Nov 22, 2004 | 09:44 AM
PurEvl's Avatar
Hey Brady,
Slowhawk (Don kinder) built everything as Im sure you know. I will have him call you guys. Thanks alot
Old Nov 22, 2004 | 10:44 AM
PurEvl's Avatar
Oh and john thanks for giving your honest assesment of the kit. I appreciate it. I want nothing hidden and everyone to know how it felt
Old Nov 22, 2004 | 10:58 AM
RealQuick's Avatar
No problem Mike. The STS bashers out there say there is lag and wont make as much power/torque as a front mount. Well, ok, but it doesnt mean they still cant perform. You made big numbers with a small t70 and you had the 9" rearend squeeling like a stuck pig!
Old Nov 22, 2004 | 12:11 PM
GONEB4U's Avatar
quote-
Now thats what I'm talking about.
Old Nov 22, 2004 | 01:23 PM
Wicked_Hugger99's Avatar
Thats frackin bad asp
Old Nov 22, 2004 | 01:29 PM
PurEvl's Avatar
going by the first car in your sig, your gonna be having fun yourself
Old Nov 22, 2004 | 01:39 PM
Blackbird's Avatar
you have dyno sheets showing the 700rwhp or is this estimated?
very impressive if it did lay it down.
can't wait to get mine running
Old Nov 22, 2004 | 01:57 PM
RealQuick's Avatar
He made 630rwhp with 10psi on the dyno and he runs 14psi on the street. I assume it is a good guess that it is ~700rwhp with 14psi (4psi should be more than 70rwhp).
Old Nov 22, 2004 | 02:15 PM
PurEvl's Avatar
I just put a 10psi spring in the wastegate on friday and havent been back to the dyno since then. Realquick is correct 10 psi it made 634hp 615tq at 4500-5000.
Old Nov 22, 2004 | 02:37 PM
Hope so, im jus gonna have learn to drive a lil (a lot) better!
Old Nov 22, 2004 | 05:44 PM
frcefed98's Avatar
Cool, I'll take that advice Hey Mike drive it up here and take me out for a spin too PLEAZE! I'll let you drive mine
J
Old Nov 23, 2004 | 12:02 AM
PatriotRedZ's Avatar
amazing! thats one badass car you have yourself there man...I for one love the
STS kits
