Still trying to decide Custom Turbo VS nitrous...
Nitrous setup:
AFR heads and sell my current heads
90mm LSX intake
90mm TB
Jesel Rockers
244/250 cam
Direct port nitrous
Turbo setup:
1.75" simple design 321 SS custom headers downswept for easy plug access
2.5 SS crossover pipe
4" SS down pipe transitioning into mild steel dual 3"
3" - 3.5" aluminum IC piping
88mm turbo
Tial blowoff valve and wastegate
Spearco Intercooler 10" tall x 3.5" thick x 24-30" wide
Wastegate mounted right before the turbo and vented externally
Current bottom end(eagle rods) swapping out the pistons for -10cc dished, katech main caps, new bearings and thermal/friction coat everything.
AC Delete: AC pump and condenser
AFR heads
Custom radiator with dual slim fans
Phil
If I were to choose between nitrous or a turbo.. I'd definitly go with the turbo.. power at all times.. then if that isn't cutting it for you save for the nos kit and have two power adders.. you'll be quick
your wish list is very nice. but i am sure some of it will have to be compromised to actually happen.
i have to say, there are like 3 turbo kits out that are allready proven and fit your car. wouldnt that be less of a hassle?
Phil
:flame suit on:
Shawn
I'm currently doing a 370" SBC Motown block based single turbo big thumper project... AFR 227's, 91.5mm Turbonetics turbo, JE pistons, oliver rods, callies crank..... Looking for 1200-1400hp and still driveable on the street. I"d like to run mid 8's and according to Youngs Performance provided my drivetrain is up to the task (ATI TH400 with brake, Denny's nitrous shaft, 4000 stall 8" fuel/blown converter) he says I won't have much trouble pulling it off..... Tuning is the only variable and i've got Gen VI DFI with a few capable DFI tuners out here to help me out with the details after I do the base tune....
So you know my vote, Turbo in a heartbeat..... If you want the nitrous you can still do that later on as a way to spool the turbo faster.....
if you are worried about being on the edge of rules with a v8 turbo, what about a v8 turbo with nitrous on top? never be legal anywhere.
i enjoy mine
