wastegate and BOV size
what size wastegate would work? what is too small? what do you base the size on? also does anyone have an opion on what is a good one for the money? im looking at Tial ones. just trying to determine size. 38mm, 40, 44?
On blow off valves. also what do you base the size on? does a $200. one really do much more than one off of a stock eagle talon? my last procharger setup had one off a talon. seemed fine.
thanks.
With these WG's I used a 50mm Tial Bov.
the bov size relates to the airflow/turbo size. stock 1G DSM BOV's start to leak at about 18 psi, and have about a 19mm hole in them. Probably wouldnt have the size to release all that air a big turbo would be pushing.
