STS turbo on LT1
Old Nov 29, 2004 | 03:53 AM
Rare96WS6's Avatar
Default STS turbo on LT1
Anyone with the LT4 Hotcam running the STS turbo? Will it perform well
on a cam with such a high LSA? I know it is not the ideal turbo cam, but
can the STS system be made to run well with the Hotcam?
Would 10.8-1 compression be ok for the 5psi system?
Old Nov 29, 2004 | 03:10 PM
BigPlanTransAm's Avatar
you probably wouldnt make much power with all that overlap and you would probably have to spray the methanol@5lbs of boost with that kind of compression. if i were you i'd change at least the cam and if possible, lower the compression.
stock cams are usually pretty good for turbos
Old Nov 29, 2004 | 08:25 PM
2ktransam's Avatar
The will not be perfect but it should work. I actually made great power with my na cam but its not perfect. I did blow a head gasket with my high compression motor which could be either from the compression or running a little lean.
